proper offset for g35x
Old Mar 15, 2011 | 03:17 PM
07g35xnick's Avatar
so I have been searching and searching and I am having a hard time finding info on the best offset for 20x8.5 forgestar f14s with 245/35/20 tires on a 07 x sedan that will be lowered on eibach springs
Old Mar 15, 2011 | 07:55 PM
lundy's Avatar
Low 30's/ High 20's with that drop.
Old Mar 15, 2011 | 07:56 PM
lundy's Avatar
what are the offset options?
Old Mar 15, 2011 | 09:08 PM
07g35xnick's Avatar
32 . 35 38 40s I'm woried about rubbing and I def don't want the tires and wheels sticking out . I might go with 20x9
Old Mar 16, 2011 | 04:41 PM
lundy's Avatar
+32 will look the best. It won't stick out either.
Old Mar 16, 2011 | 05:31 PM
07g35xnick's Avatar
thank you for the input
Old Mar 27, 2011 | 06:39 PM
djfarhan's Avatar
so i find out that the miro 19 x 8.5s come in 15 for offset and the 19 x 9.5 in 20.
school me on the whole offset thing and tell me what i should ideally have for offset on my 07 X sedan for a non staggered 19s setup? ;-/
p.s. the ASAs come with Offset: 45mm
Old Mar 28, 2011 | 11:50 AM
AesonVirus's Avatar
Old Mar 28, 2011 | 11:54 AM
djfarhan's Avatar
^ thanks scott!
Old Mar 29, 2011 | 09:11 PM
07g35xnick's Avatar
after all the searching i have done all i can come up with is nobody is using +32 offset with 20x8.5 wheels and most of the pics i need to see for info dont work on the database. most people are using a +35 or higher with the x sedan in 8.5 wide wheels. please feel free to chime in on this, im not trying to make a 2k dollar mistake u know. what im looking for is a little less then flush all around with a 20x8.5 245/35/20 tire. im going to look at what i have when i decide on wheels and may lower it on eibach at some point
Old Mar 29, 2011 | 09:22 PM
ChinkyChoy's Avatar
i am running 19x8.5 +25 all around and i have an X but i am dropped on BC Coils
Sorry i know the pix are at a bad angle just search for my thread for more pix
Old Mar 29, 2011 | 09:28 PM
07g35xnick's Avatar
car looks nice. does it matter that im going to get the forgestar f14 wheels as far as offset?
Old Mar 29, 2011 | 09:41 PM
ChinkyChoy's Avatar
like as in if my my wheel's +25 will be different from another wheel's +25 offset? i dont believe so all offset should be the same because like the links above explained where its measured from.
i believe the +32 or +35 would be your best bet but its only a matter of mm difference and worst comes to worst just slap on some spacers
Old Mar 29, 2011 | 09:51 PM
07g35xnick's Avatar
ok so would the safer of the two be the 35 so that i could add a spacer instead of having to machine the wheel?
Old Apr 10, 2011 | 10:27 PM
G-MAN (CANADA)'s Avatar
Question would this be different for a G sedan S? I'm thinking of running the exact same setup for my S.
seagrasser
May 3, 2022 09:43 AM
NailBomb
Oct 28, 2015 07:53 AM
leo38cheng
Sep 29, 2015 05:43 PM
leo38cheng
Sep 25, 2015 01:47 PM
lavtxa
Sep 21, 2015 11:51 AM
