DIY: Applying Vinyl Roof Overlay (with Fin and Sunroof)
Old Sep 7, 2011 | 11:02 AM
soundmike's Avatar
Heads up! Just posted this, with photos, on the site
http://gshack.org/?p=298
Tools:
* Xacto knife or blade
* Spray bottle with 70-30 solution of water/dishashing soap (some prefer mixing alcohol into this mix, but i find this solution to work just fine)
* Clay bar
* Painter’s tape
* Silicone or felt-tipped squeegee (a credit card will also work, but please cover it with a microfiber cloth, the plastic will scratch the vinyl).
* Hair dryer (or heat gun if you know what you’re doing)
* Extra hands (optional)
Steps:
  1. Thoroughly wash and clean the entire roof of the car.
  2. For further cleaning, run a clay bar through it at least once and wash again.
    Tip: Keep the sunroof closed until step 9.
  3. Position BlueBatmobile’s roof overlay to get a feel for where things should be. The overlay came with the sunroof portion already cut-out.
    The vendor was also kind enough to mark where the shark-fin antenna will likely fall into. I suggest cutting out the hole before proceeding, this will help “anchor” the overlay to the roof as well as make laying it down easier. For better results, trim to about 1/2″ away (inside) from the marked area (i.e. you should have at least 1/2″ of excess material covering the fin, to allow for final adjustments).
  4. From the sunroof area towards the rear of the vehicle, apply painters tape to attach the aft section to the car. Taping comes especially handy if you’re going at this solo.
  5. Fold back the front area and slowly peel away the backing sheet. Spritz some solution to the peeled vinyl to keep it from sticking to itself. Spritz the roof as well. Tear the excess backing sheet from the part you just folded.
  6. Position the newly spritzed vinyl back onto the roof and squeegee away the bubbles and excess fluid. It’s okay to have excess vinyl at the edges – we will trim these out after all is said and done.
    Tip: Feel free to stretch, heat, peel back and re-apply sections of the vinyl to rid itself of folds and wrinkles, or that stubborn bubble.
  7. With the front in place, tape just to the edge of it, as shown in the photo. Remove the tape from everywhere else and fold back the vinyl. As with step 5, peel back the backing sheet and spritz solution to the vinyl and to the roof.
  8. Lay the vinyl towards the rear and squeegee away.
    Tip: I found it easiest to squeegee from the center moving towards the sides then corners. The closer you get to the corners, the more chances of wrinkles but stretching or heating the vinyl a little at a time until you’ve “pulled” the vinyl beyond the edge works fairly well.
  9. Open the sunroof and tape the deflector down to keep it tucked away for now. Make small relief cuts just before and after the sections that curve (i.e. corners). This will help you with folding down the vinyl neatly. Run the squeegee towards the direction of the sunroof to remove any remaining bubbles.
  10. It doesn’t take much to keep them down, so feel free to trim any excess. I trimmed roughly 1/2″ all around.
  11. We’re almost there! Now to trim the excess around the outside edgegs of the vehicle. Before doing so, check everything and make sure there is no other bubble or wrinkle elsewhere. Run the squeegee and make adjustments as necessary, moving towards the outer perimeter of the vehicle.
    Tip: Go slowly on the trimming. There are “channels” on the side rails and before the roof meets the front/rear glass, i found these to be the perfect place to do the trimming without hitting metal or rubber trim.
  12. Let the vinyl dry for a couple of hours then wash away all the mess. Very tiny bubbles will dry out after a couple of days, larger bubbles can be popped with a needle (i used the Xacto tip).
Old Sep 7, 2011 | 12:05 PM
LuCanHang's Avatar
Nice DIY.
Old Sep 7, 2011 | 04:01 PM
Blue_Batmobile's Avatar
Official Sponsor of the Florida G35 Club
Mike, awesome write up! You mind if I use it for reference? U need some nice installed pics in the light !
B@t
Old Sep 7, 2011 | 04:06 PM
E-Ticket Ride's Avatar
Mike, did you leave the sharkfin body color?
Old Sep 7, 2011 | 04:38 PM
soundmike's Avatar
Originally Posted by Lcolin25
Nice DIY.
Thanks.
B@t
Be my guest
Yep, but if one were to want to wrap it, the excess cut-off should belarge enough to cover the fin with a little stretch. I like it sticking out body-color
Old Sep 7, 2011 | 09:24 PM
kool_yaar's Avatar
nice DIY as usual mike!
Awaiting VQs comments in 3..2...1...lol
Old Sep 12, 2011 | 04:10 PM
more pics!!!
B@t
Old Sep 12, 2011 | 05:06 PM
SuperCleanG's Avatar
Vinyl is the one thing I cant seem to master.. nice work!
Old Sep 13, 2011 | 05:03 PM
more pics!!!
B@t
Old Sep 15, 2011 | 07:31 PM
pbabajan's Avatar
this might help as well
http://youtu.be/HVKxbXINPdo
Old Sep 26, 2011 | 04:24 PM
there you go .
B@t
Dallsinghjr1
Sep 17, 2023 11:25 AM
g.spot
May 9, 2016 10:54 PM
R350k5
Lights
Jan 12, 2016 09:22 AM
