Nissan Power Pup Bullydog - First Impressions
Old May 14, 2009 | 01:14 AM
  #211
bat6wc's Avatar
would this be beneficial to a completely stock engine?
Old May 14, 2009 | 12:08 PM
  #212
johnblaz2000's Avatar
Good News, My Bully Dog arrived today and I am stuck @ work till 5. :O
Old May 14, 2009 | 04:10 PM
  #213
jack090's Avatar
Originally Posted by ketchupfreak
I will be receiving my Bullydog today and Im just wondering what does advancing the timing exactly do? I'll be running CA 91 oct gas if it matters at all. Are there any ill effects from doing this?
Advancing the timing in laymans terms (correct me if I'm wrong) means that your engine will be burning a little bit more fuel to make higher combustion inside the engine. To much and it will "ping" meaning it has predetonated ("running to rich on your fuel"). 2 Degrees is so little (which is what the max the bullydog can change) that it won't affect much. Also if you use higher octane fuel it will prevent predetonation which means you can have higher combustion. If you decrease your timing it's called "running lean". There's a whole science to timing and compression ratios (especially with forced induction) that you want to find the optimal ratio. Our engines are equipped to retard timing if it detects pinging. (Which is why you can run 87 octane gas and it will produce less horsepower, but produce more HP if you run premium) I'm not an expert at all so you may want to use "the google" to research it more.
BTW. I use 93 octane in Tennessee, which is why I went ahead and increased my timing by 2. The nice thing with a bullydog is that you can change it anytime you want to.
Yes this will benefit a stock engine, however I believe if you have more MODS (I.E. Intake/Exhaust) you will get even more power. I'm almost completely stock (just have an intake) and noticed improvements (described in the first post to this thread).
Old May 14, 2009 | 05:51 PM
  #214
Austin713's Avatar
Increasing timing has nothing to do with the amount of fuel you are adding. it just changes when the spark goes off to start the power stroke of the engine. the farther you advance it the farther the cylnder travels on the compression stroke before the spark plug fires. this added pressure creates alot more heat and so a higher octane fuel must be used (more octane=more resistance to predetination from too much heat) in exchange for this later spark you get a longer power stroke and a more powerful one at that. that is where the power increase comes from.
I used to have a diablosport programmer on my Mustang GT (before the G)and when i fully advanced the timing on it i could feel a world of difference at WOT.
Old May 16, 2009 | 01:38 AM
  #215
kendroz's Avatar
Yesterday I received by email the 1.2.2c revision for my car. I select the premium configuration with 7850rpm limiter. On the settings menu I notice that they program -2deg of timing in premium mode. In full throttle acceleration from a standstill it feels faster. After 3500rpm and higher is very good. Because I have FI HFC's and I eliminate the y-pipe and have H-pipe, the idle speed is smooth now. Before the ecu feels more air and sent more fuel causing that when I start the engine, it shuts down (too much gas in the mix). Also the service engine soon turns off. High speed runs are SCARY now because my front tires are 245/45/18 instead of the 225/45/18 it has before (Toyos T1R do not offer 225/50/18, so I have 245/45/18 all around).
WARNING - if you raise your speed limiter, you will hit more than 150mph in 4th!.
Finally it is a great upgrade for people that don't need to tune the car too much.
KD
Old May 16, 2009 | 02:51 PM
  #216
How do you get the 1.2.2 Update? I Only have the 1.2.1 Update and it isn't working for the car..
Old May 16, 2009 | 10:12 PM
  #217
PursuitofG's Avatar
quick post.
I got a completely stock G35S, performed the tuning which was easy, as previous noted it took roughly 20 mins initially to read the ECU.
Only changes I made was switching to premium,increasing timing +2, upping the speed limiter to 170 and rev to 7950
While out on a quick run I did noticed a difference in power in some instances i.e. from a dead stop (flinging my gf back in her seat ), However did encounter some unresponsiveness, in one case I was cruising at 80 and mashed down for more and got nada in return (VDC enabled and not in DS mode)
Old May 17, 2009 | 10:02 AM
  #218
AesonVirus's Avatar
Cheapest I'm finding is $373.
They have them on Amazon for the same price as well. (with free shipping)
BullyDog is selling them for well over $400 on their site.
Old May 17, 2009 | 10:30 AM
  #219
G35Now!'s Avatar
Moderation-free
?? They're still $353 on that link I provided, and $20 off...?
Old May 17, 2009 | 11:44 AM
  #220
AesonVirus's Avatar
That link is bringing me to a page for specials and new products.
I searched for BullyDog as well as "60A2025A0A0" and came up with the Ford model.
I didn't think that was the correct one but looking again, it looks like the correct product but the wrong picture.
Old May 17, 2009 | 12:21 PM
  #221
PursuitofG's Avatar
http://www.autoanything.com/performa...0A2526493.aspx
coupon code AA20DEAL for $20 off with free shipping
Old May 17, 2009 | 03:21 PM
  #222
AesonVirus's Avatar
Thanks guys.
Old May 17, 2009 | 03:28 PM
  #223
bat6wc's Avatar
i cant decide if i want to buy!
Old May 17, 2009 | 05:40 PM
  #224
AesonVirus's Avatar
On the fence between this and the Ravspec rear diffuser.
I've had to curb my appetite and mod spending lately.
Old May 17, 2009 | 08:05 PM
  #225
Can anyone who have the bully dog forward me the link for the 1.2.2 update?
