torn between which exhaust to get..
Old Sep 3, 2009 | 02:34 PM
  #46
Austin713's Avatar
Originally Posted by CalsonicVQ
My left muffler tip is perfectly centered, but the right one is towards the center. I think it might related to the hanger welded on the muffler. I know most other people won't notice, but of course everyone is **** with their own cars.
Anyway, I will definitely try InTgr8r's tip (no pun intended) when I have the chance.
That was exactly what i was thinking!! when i installed them it looked as though they were angled the wrong way. nobody will notice but i do... i was thinking about getting under there with a butane torch and heating up the hangar while pushing on it in the direction i want it to go.
Old Sep 3, 2009 | 03:29 PM
  #47
InTgr8r's Avatar
Staff ALUMNI (retired)
^ thought about the hangar too, when I installed.
The hangar is on the rubber isolator, so it moves no problem.
Tweaking it at the slip joint worked perfectly.
Old Sep 3, 2009 | 07:03 PM
  #48
2007BlueSlate's Avatar
I know with a lift it would be easy to get under the car but how easy it to actually install all the parts of the exhaust? Would I be able to do this myself/what problems would I run into?
Old Sep 3, 2009 | 07:23 PM
  #49
mishmosh's Avatar
You can easily install the exhaust yourself. Put car on 4 jackstands by jacking up the front and then the rear.
Old Sep 3, 2009 | 09:18 PM
  #50
InTgr8r's Avatar
^WHS +1
I did mine in my garage no problem.
Old Sep 4, 2009 | 11:06 AM
  #51
Austin713's Avatar
yea same here. 4 jackstands is a plus. i used 2 in back. hardest part was breaking the bolts on the Cats loose. you may need a friend to help lift the center section into place while you get all the bolts in.
Old Sep 4, 2009 | 01:39 PM
  #52
Austin713's Avatar
One question for you guys... the rubber isolators that hang the cans themselves (the farthest from the front of the car) are attached to a square bracket. this bracket is held on by 2 bolts and has an arrow on it facing a certain direction. which way should this arrow be facing?? mine are facing towards the front of the car.
Old Sep 4, 2009 | 09:43 PM
  #53
InTgr8r's Avatar
Idk ....
I had a quick look at the SM, but it isn't very clear.
It does look like there is only one way though.
....I'll have a look next chance I get.
Old Sep 4, 2009 | 10:52 PM
  #54
mishmosh's Avatar
The arrows are facing forwards on mine.
Old Sep 8, 2009 | 11:16 AM
  #55
Austin713's Avatar
cool thanks, i actually ran by a muffler shop and they were able to push out the angle on the hanger without any heat and it looks perfect now!
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
Albanian122
Sep 12, 2015 04:02 PM
