high idle after warmed up?
Old Sep 28, 2009 | 08:12 PM
homer_atl's Avatar
hi all.
I have a 2008 6MT sedan. This past weekend, i drove the car around running errands for about 30 minutes. I noticed that when i get to stoplights, the idle rpm felt a little high. It's at about 1200 rpm. Is this normal? I dont recall it running this high especially after the car's already warmed up. I had the AC on also, but i always drive w/ the AC on. BTW, the weather in my area that day was around 80F. Pretty nice day.
That night i checked and my reserve tank for coolant was empty. I filled with water (all i had at the time).
Any ideas?
Old Sep 28, 2009 | 10:19 PM
G35Now!'s Avatar
Moderation-free
1,200 is high, even with the A/C on. If it's a continuing problem, take it to the dealer.
Old Sep 28, 2009 | 10:26 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
+1 that's definitely high
Old Sep 29, 2009 | 10:37 AM
homer_atl's Avatar
no one else had this issue? the solution was?
if i get no results, i guess my last resort is to goto dealer
Old Sep 29, 2009 | 10:52 AM
copmiami's Avatar
I have a G35 sedan, platinum, premium pkg...has 102,000 miles on it and just got it serviced yesterday and noticed that its idling higher than usual even when the engine has warmed up. It's idling at 900-1,000 at a stop light without the a/c being on. Is this too high?
Old Sep 29, 2009 | 11:08 AM
G35Now!'s Avatar
Moderation-free
You have a 2nd gen with 102k miles? If that's correct, think that makes you the winner!
That sounds high - per my BullyDog, my idle is set at 800 (stock) when warm, and it usually stays around there.
Old Sep 29, 2009 | 02:42 PM
homer_atl's Avatar
my car has about 27k mi on it and it has this prob, so that makes my car the loser
Old Sep 29, 2009 | 07:38 PM
dghboybigboy's Avatar
I had a bad coolant sensor not too long ago. My car would idle super super low and the temp was super low as well. Take it to the dealer and have them check out the throttle bodies and make sure all the sensors are working properly. That's my only guess, or your carpet is hitting your throttle? Heard on the news of a tragic car crash involving a IS 250 from Lexus, they're car was out of control and couldn't slow down. Come to find out it was the carpet getting stuck under the throttle. Never hurts to look you know :P
Old Sep 30, 2009 | 03:00 AM
pfarmer's Avatar
I think it is actually the floor mats on the Toyota which looks to be blocks just the right size for the pedal to get stuck in.
Old Sep 30, 2009 | 10:27 AM
homer_atl's Avatar
good input, but i looked. unfortunately it wasn't that simple a fix. guess i'll goto dealer soon...
Old Oct 3, 2009 | 09:38 AM
homer_atl's Avatar
ok. went to the dealer yesterday. they fixed it. turns out i had some crud on the AFM. It sounds about right cause i haven't changed any of my air filters :P
After getting the car back, it's amazing how smooth the car feels. I guess i should do my routine maintenance... heh heh. just glad it was a quick fix..
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
vamarris
Sep 26, 2015 12:56 PM
