MOD: Make your X 100% RWD. NO JOKE
Old Jul 5, 2012 | 03:53 PM
  #106
freakta's Avatar
Hahaha it works well and the car is still really grippy in 2wd
Old Jul 23, 2012 | 12:39 AM
  #107
woostar88's Avatar
Originally Posted by smar
Hey, all I did to put in a switch for my awd was put a fuseswitch in from the fusebox on the drivers side by the e-brake. No cutting into any factory wires...just pull the awd fuse and pop in a fuseswitch which I got from a R.V. store then mount my switch in the dash above it beside the vdc switch. Might cost $10 more but I rather that then cutting.
I'm bumping the old thread.
I would like to know more about how to do this.
I see that there is labeled awd. So basically I buy a fuse tap and place a fuse and connect it to a switch?
And how will it kill the power?
I'm not sure how to do this
Old Sep 4, 2012 | 06:14 PM
  #108
G3Sx's Avatar
Has anyone with this mod had their car in drive with all four wheels in the air (jack stands or lift) to see if any power at all reaches the front wheels? Why do all serious turbo/supercharger installers that know what they're doing still revert to dropping the front driveshaft before tuning the car on a dyno instead of doing this? Is it lack of knowledge, or is there more to it?
Old Sep 5, 2012 | 03:28 PM
  #109
GXXXV X's Avatar
^good question, I'm interested to know the answer as well!
Old Apr 5, 2013 | 12:06 AM
  #110
Mt.Fuji Monster's Avatar
bump
Old Sep 21, 2016 | 11:55 AM
  #111
AJC128's Avatar
It works
Just did this to my 07 X yesterday switch and all and it works great. I still shut my car off before changing from awd to rwd and rwd to awd. VTC does still work with rwd only and you can do "burnouts" and slide around now. I just have a simple interrupter switch ( will post pictures later.
My question to the original poster do you or have you switched without shutting off your car first?
Old Feb 13, 2017 | 01:34 PM
  #112
ferrari71298's Avatar
Thumbs up I made "the switch"
Here's what I ended up doing. took a dremel to the plastic pieces and it fits very well. very clean install. works great. thanks for the write up borderline.
more info here https://g35driver.com/forums/g-spot/...today-467.html
Old Feb 13, 2017 | 08:35 PM
  #113
borderline's Avatar
I'm glad to see you enjoy it ! I no longer have a G but probably a Q50 RS as my next car
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
