VDC Off/Slip Light + Hard Shifting (AT)
Old Oct 30, 2013 | 02:26 PM
GMan85's Avatar
2007 G35X w/ 103k miles automatic transmission. Recently had all my tranny fluid's changed and my front brakes replaced (rears need new rotors and pads soon).
I understand these lights will come on if I'm short on brake fluid or if I need to change my brakes but I doubt this is the issue. Both of these lights came on randomly last night and my car was shifting horribly. Both the upshift and downshift were rough. I was unable to hit the switch to turn on VDC again.
When I started the car this morning, both lights are off and the car runs fine again. Has anyone ever had this issue? I don't believe my brakes would have anything to do with the rough shifting but I'll have the rear brakes replaced until I can find a solution. I'm hoping this was a one time thing that happened randomly and that it won't be a major issue.
Old Jan 4, 2016 | 06:28 PM
GMan85's Avatar
Reviving this thread from the dead. Same issue happened again this past week. Does anyone have any experience with this?
Old Nov 18, 2016 | 05:55 AM
Shotiko's Avatar
nobody have answer? i had same problem too, but i can not find out why it happening.
Old Nov 22, 2016 | 06:06 AM
Blue Dream's Avatar
I drove ttrank's car solo
Only thing I can remotely suggest is check the level of your AT fluid and change/refill if necessary. Sounds like it could just be a computer glitch since it happens so randomly. Have either of you had your cars scanned for any trouble codes? Sometimes they will occur but not trip the SES light. Just spitballin' here though.
Old Nov 9, 2017 | 03:30 PM
Jude v's Avatar
Did you ever figure out the problem mines doing the same thing.
Old Nov 9, 2017 | 07:51 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Pay for a diagnostic at Nissan and they will tell you exactly what the problem is for about $150. Sometimes this is the easiest option, then you can decide how to proceed with the repair.
Old Sep 22, 2019 | 04:25 AM
Jvq35hr's Avatar
G35s sedan vq35hr
Did you figure this problem out?
Old Sep 26, 2019 | 12:47 AM
Jmello36's Avatar
G35X
Have you taken your front wheels off or rotated tires before lights started? When you turn a corner going between 2000-3000rpms does front end feel like its locking up or hitting the brake intermittently?
Old Sep 26, 2019 | 12:51 AM
Jvq35hr's Avatar
G35s sedan vq35hr
No none of that. Car works outstanding until I hit 6k rpms I don't get up on the rpms much. Just every now and then we all do, but since this. I dont let it pass 6k.
Old Aug 20, 2020 | 09:23 AM
John Dunham's Avatar
M56
Edit: my reply is regarding the VDC and not the 6k.
I am not a frequenter of this forum; however, I searched and found this symptom and am also experiencing it with my 2011 Infiniti M56.
Occasionally, the car will have difficulty turning over, slow cranking, but starting. When this happens, the VSC and radar sensor ( used for lane departure and speed control) lights are on. As well, the transmission hard shifts and lightly surges when slowing to a stop. Restarting the car clears the issue up.
I’ve had Infiniti look at a dying battery issue for years that has been traced back to an emissions function that won’t allow the alternator to charge the battery, unless the car has been driven for 8 miles or more. Running as designed is what they say. Also, I had an additional 4 gauge battery cable installed, as the factory charge cable was undersized.
Any other thoughts why this could be happening?
Jeruel Morales
Feb 21, 2019 01:02 PM
luger303
Nov 2, 2010 12:44 AM
Nightm4re
May 8, 2010 03:29 PM
edpark30
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2009 11:39 AM
mubay
Nov 18, 2007 10:33 AM
