Wheel Bearing Service Interval.
Old Mar 7, 2021 | 10:59 AM
Serge Mullen's Avatar
At what mileage did you need to replace your wheel bearings on your V36 sedan?
Also what would you recommend as a decent replacement, or are they all created equal?
Old Mar 7, 2021 | 12:46 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Wheel bearings can last as little as 50k miles or as much as 200k.
Replacement depends on a LOT of factors, how hard is the car driven on corners, are there wheel spacers, is it aligned regularly, etc.
Stick with a name brand for long life, Moog would be your upper end, same with Timken. Timken is probably a more popular replacement for this chassis, excellent reputation.
Old Mar 9, 2021 | 08:05 PM
Thanks Cleric. Doing a search most of the results come back without any real name brand. I did find Timken but they were about 30-40% more.
Anyway I grabbed a pair of 'Kugel' bearings. Will be replacing both fronts, hope the quality is ok, will report back.
Old Mar 9, 2021 | 09:10 PM
cleric670's Avatar
BANNED!!!
If you're stock alignment, no wheel spacers, and drive "normally" you'll probably get 50-80k miles out of them.
Old Mar 9, 2021 | 09:13 PM
I see, I'm guessing that's on the low end of the spectrum. Approx how much would a timkin be good for?
Old Mar 9, 2021 | 09:17 PM
cleric670's Avatar
BANNED!!!
80k-120k for a stock normally driven car. You may get a little more but probably not going to hit 150k on the stock wheel bearings.
Old Mar 10, 2021 | 07:54 PM
Mine started making noise at about 110K miles.
Old Mar 11, 2021 | 09:31 PM
Got the new bearings installed today. The ones I ordered were a bit of a head scratcher so we opted to order another set (CBK) from the local parts place that were an exact match, although curiously they appeared to be for 2009-2014 models. Mechanic opted not to remove the vehicle speed sensor saying there is a good chance it will get damaged, and instead opted to cut a section in the shield or end cap in order to get it to pass through. Old bearings were in rather pitiful shape.
Kugel bearing I ordered. As you can see the cap or shield is not - i guess you could call it 'rolled' - almost like they omitted this step at the factory.
14 yr old bearing:
What it should look like:
So quite an ordeal, nothing ever goes exactly to plan. On the plus side the car glides now like a Cadillac.
Old Mar 12, 2021 | 06:06 PM
cleric670's Avatar
BANNED!!!
Yeah that's definitely a manufacturer defective item. Glad you got it all sorted out.
Old Mar 9, 2022 | 11:57 PM
lightmeupper's Avatar
G35X
I got 180k miles out of my oem bearings on my 2007 g35x. Changed them after 14y. Fronts were easy. The rears was a bitch to get out.
Old Mar 10, 2022 | 06:52 PM
Triton3.5's Avatar
Had to replace my fronts at 65,000, lots of auto x on those and high speed running, haven't touched the rears yet This in on an X btw.....
Went with SKF.
Old Apr 19, 2022 | 12:58 PM
QX1's Avatar
QX1
Skf
what about SKF? They used to be top before?
Schparky
Apr 28, 2020 09:48 AM
G35-R
Jan 5, 2014 04:37 PM
Bigd2k6
Mar 5, 2010 02:45 AM
DougJones
Sep 5, 2006 02:13 PM
