Heated Seats
Old Nov 30, 2007 | 01:23 PM
mummaiv's Avatar
Heated Seats
Just checking to see how your seats work. I have had other cars with heated seats and they heat very quickly. This morning it was 32 degrees. I started the car and turned the seats on HI. I came out 30 minutes later and the seat was just a little warm. About 15 minutes into the drive the seats got hot. Does it always take this long?
Old Nov 30, 2007 | 02:06 PM
hyukki's Avatar
It could be that since you weren't in the seat to get all the heat transfered to your body, it dissipated into the surrounding air...
Old Nov 30, 2007 | 02:11 PM
mummaiv's Avatar
I don't think so. I have a Navigator and an R Class Benz and never had this problem. I traded a Audi A3 on the Infiniti and when you let the car warm up in the AM the seats were always toasty.
Old Nov 30, 2007 | 03:05 PM
hyukki's Avatar
Ah, I see.
kvangil's Avatar
No matter how cold it is outside, I can usually feel the heat within 5 minutes....
Old Nov 30, 2007 | 03:56 PM
Cali G's Avatar
Mine feel very slow to kick in vs. other cars i've been in.
Old Nov 30, 2007 | 03:59 PM
mummaiv's Avatar
I have an appointment to drop off at the dealer ( 60 miles one way). Service says they have had issues with the seats.
Old Dec 6, 2007 | 02:05 AM
jalilig35's Avatar
my seats take a while to heat up sometimes they heat up and sometimes they dont and sometimes its really warm and sometimes its not as warm on the same position. something wrong with my seats? covered under warranty?
Old Dec 6, 2007 | 03:03 AM
hyukki's Avatar
I don't know about you guys... but I'm perfectly fine with my heated seats. Maybe I don't have the problems you guys have but I'm getting a feeling that you guys are very picky. Depending on the temperature around you, the seats could feel hotter than usual or whatever.
Old Dec 6, 2007 | 03:04 AM
hyukki's Avatar
And yeah, mine takes about 2-3 minutes to kick in but I'm fine with it.
Old Dec 6, 2007 | 01:32 PM
Sieveboy's Avatar
I think the heated seats are optimal, at least for me, the high setting gives heat in a minute of two, whereas the low setting can be left on all the time, gently toasting my a$$, without getting too hot.
Old Dec 11, 2007 | 09:58 AM
mummaiv's Avatar
I picked up my car from the Infiniti dealer last night. They performed the TSB on the heated seats and there is a huge difference. They heat up in about 2-3 minutes. It was worth the 70 mile one way drive!!
Old Dec 11, 2007 | 10:55 AM
st1sj's Avatar
warmed up the car for 30 mins?
Old Dec 11, 2007 | 11:05 AM
mummaiv's Avatar
Wake up - start the car, go back inside and get ready for work, etc. Gets cold here in PA.
Old Dec 11, 2007 | 09:02 PM
hyukki's Avatar
What, exactly, was the issue you were having with your seats?
Did you know that the TSB was for temperature differences, not because they warmed up slowly? Having said that, I doubt your heated seats heated up "faster" after your TSB.
2007 INFINITI G35 SEDAN; TEMPERATURE DIFFERENCE WHEN USING HEATED SEATS
With the seat heater in the on position:
1. You confirm that there is a temperature difference between the driver’s seat and passenger’s seat.
AND/OR
2. There is a temperature difference between the bottom cushion and the backrest of the passenger seat.
