Anyone change to a 4.083 gear?
Old Dec 31, 2007 | 04:40 PM
GEE35FX's Avatar
Originally Posted by Cali G
I've now read information that the ratio for the 2nd gen G35 sedan is 3.69 in the 6MT and the 5AT.
Does anyone know where I can confirm this?
That is correct it is that ratio in all 2nd gen sedans.
You can check here: http://www.infinitinews.com/index.html Go to Infiniti, then specs for 07 or 08
Old Dec 31, 2007 | 07:03 PM
Cali G's Avatar
awesome, thanks man:
'07-'08 G35 Sedan and '08 G37 Coupe:
Old Dec 31, 2007 | 07:11 PM
Klubbheads's Avatar
it should be very interesting to see. Raising the rev limiter to 8k, cams, and with a final drive of 4.083 this car would really move. easily low 13 second car. Can't wait to see when someone does this.
Old Dec 31, 2007 | 07:33 PM
Cali G's Avatar
Interestingly...
'07-'08 350z Coupe, NISMO, Roadster:
Old Dec 31, 2007 | 07:58 PM
Cali G's Avatar
Stock 3.692
RPM ..1st Gear.. 2nd Gear.. 3rd Gear ..4th Gear... 5th Gear... 6th Gear
7500..... 43 ...........69........... 99 .........127.......... 161............ 203
vs.
4.083
RPM.. 1st Gear ...2nd Gear... 3rd Gear... 4th Gear ...5th Gear... 6th Gear
7500 ......38........... 63............. 90............ 115......... 146 ...........184
now my shift to 4th will be worth while, instead of just being in 4th for 3mph.
I'm getting pumped!
Old Dec 31, 2007 | 08:05 PM
Cali G's Avatar
RPM .... mph in 6th gear
2400 .........65
2500 .........68
2600 ..........70
2700 .........73
2800 .........76
2900 .........79
4.083:
2600 .......... 64
2700 .......... 66
2800 ...........69
2900 .......... 71
3000 .......... 73
3100 .......... 76
3200 .......... 78
3300 .......... 81
Old Jan 1, 2008 | 08:24 PM
07-G35-MT/S's Avatar
This car should have come with this gear ratio. In comparison tests, cars with less hp usually nip at G's heels because of the tall gears.
Old Jan 2, 2008 | 02:39 PM
Klubbheads's Avatar
Stock 3.692
vs.
4.083
I'm getting pumped!
4.083 looks so much better.
Old Jan 2, 2008 | 02:50 PM
Cali G's Avatar
Yea.. it looks like it was made for this car. I'll hopefully be correcting Infiniti's mistake of leaving it at 3.692 soon after my exhaust sells.
Old Jan 2, 2008 | 04:14 PM
_jb's Avatar
_jb
Photographer
I have 4.083 gears and a Carbonetics LSD. The LSD isn't required as I had the OEM VLSD, but if you're ever going to add one, changing gears is the time to do it. Here's a chart with the RPM in each gear with a 6mt, 4.083 gears, and 285/35x19 rear tires.
4.083 gears are a great mod!
Old Jan 2, 2008 | 04:23 PM
GEE35FX's Avatar
Awesome, have you run it at the strip?
Old Jan 2, 2008 | 04:26 PM
Klubbheads's Avatar
+1 on this. Also if u did what did other 6MT G35s get on that same day?
Old Jan 2, 2008 | 04:46 PM
Cali G's Avatar
you cut us off 500-1000rpm early
I tried to prnt scrn / paste that and host it from that site, but it didn't all copy right so i just recorded snipets.
Old Jan 2, 2008 | 05:44 PM
_jb's Avatar
_jb
Photographer
Not yet.
Old Jan 2, 2008 | 05:48 PM
  #30
_jb's Avatar
_jb
Photographer
Here's a link to the site where I calculated it:
http://www.f-body.org/gears/
You can put your own redline and other information in and calculate whatever you want.
