Anyone change to a 4.083 gear?
Old Jan 27, 2008 | 04:26 PM
  #46
07-G35-MT/S's Avatar
Check this out.
http://www.vibratesoftware.com/html_...s.htm#Frontier
There are plenty of other gear ratios from other rwd models as well.
Only question I have is whether it will interfere with cruise control and traction control.
Used parts could keep overall price in check.
Old Jan 27, 2008 | 04:51 PM
  #47
_jb's Avatar
_jb
Photographer
It doesn't interfere with the cruise control on my '05 6mt Coupe... or traction control...
Old Jan 27, 2008 | 08:55 PM
  #48
blnewt's Avatar
What would this mod do to the factory warranty??
Old Jan 28, 2008 | 11:32 AM
  #49
IvoryPearl07G's Avatar
void the whole power/drivetrain most likely....
when you mod anything, it will void all related parts.
so is anyone going to attempt this??? I wanna do it, but need to see a guinea pig do it first
Old Jan 28, 2008 | 01:02 PM
  #50
_jb's Avatar
_jb
Photographer
I don't think it would void the entire driveline warranty... especially if you had an Infiniti dealer install the gears.
Several people already have 4.08 gears... Great mod...
Old Jan 28, 2008 | 01:12 PM
  #51
crashnburn's Avatar
do the 4.08 gears help at all at the dragsstrip.... arent 4.10 gears 1/4 mile gears for camaros and such
Old Jan 28, 2008 | 01:28 PM
  #52
Cali G's Avatar
How would the dealer even notice the gears? Odds are they won't cause any problem, and 2nd of all, they probably wouldn't notice there was a different OEM part in there than stock.
Old Jan 28, 2008 | 01:41 PM
  #53
_jb's Avatar
_jb
Photographer
They are very popular with drag racers...
One of the first guys to get them picked up a couple of tenths in the quarter mile... in a Z...
Old Jan 28, 2008 | 01:56 PM
  #54
G35Now!'s Avatar
Moderation-free
Why is this just a 6MT mod - the differentials should be the same on Sport models between AT and 6MT?
Old Jan 28, 2008 | 01:59 PM
  #55
snowcrossmxz's Avatar
its a good chance they would be the same, check the specs. the X might be different tho,
Old Jan 28, 2008 | 02:14 PM
  #56
_jb's Avatar
_jb
Photographer
Technically, it's not just a 6mt mod... But there are two issues with 5at cars...
Automatics don't need as low a gear as manually shifted cars do. I know of one guy with a 3.91 gear in an automatic. I don't know of anyone with 4.08's in a 5at.
5at cars have a different, thicker ring gear. The 4.08 gears will not fit on a differential from a 5at car. You can get a different diff or swap in a different pumpkin, though.
Old Jan 28, 2008 | 03:38 PM
  #57
G35Now!'s Avatar
Moderation-free
Thx!
Old Jan 28, 2008 | 05:22 PM
  #58
g u l8er's Avatar
it should fit seeing how its off a nissan truck with auto tranny. i have 4:10's in my camaro and they were a good bang for your buck mod.
Old Jan 28, 2008 | 05:27 PM
  #59
crashnburn's Avatar
guess im going to do more research and gears will be my next mod
Old Jan 29, 2008 | 09:23 AM
  #60
yea i know but, alot of the less experienced guys will get the same answer from a dealer if they ask them about it. Although, some dealers will install the parts but only warranty THEIR own work. Not all dealers will do it if the part is not a vehicle specific oem piece. The dealer only gets the money from corporate for warranty work if an infiniti oem part has failed.
If the dealer can't prove that an infiniti part did fail and an aftermarket part is in question, they simply cannot warranty it.
I know from experience you can easily get away with any mod if you know how get it by the dealer. One way is by not going to the dealer if you have modified an area of the vehicle that has broken.
The other is that if you do go, for a problem in that area, fix it yourself or uninstall the aftermarket part.
you should be able to get around the whole warranty issue for the gears. but if your diff blows out, might need to think about my suggestions
