My morning at Fast Intentions ...
Old Jan 26, 2008 | 04:37 PM
  #136
Inversed's Avatar
What do you expect the final gains to be? The dyno charts seem to be a bit low.
Old Jan 26, 2008 | 04:45 PM
  #137
terrycs's Avatar
Unfortunately, you'll never see the same numbers twice. On my car, they averaged three stock runs, resulting in 243.2Hp / 203.7 ft-lb. But the numbers vary a bit between runs.
For example, we could inflate the power gains by picking the lowest stock run vs. the highest FI run. That would come out to around 10.3 Hp gained.
Again, there is more drivetrain loss in an automatic and also more variations due to the test environment.
In short ... it's not possible to get standardized HP and torque at the wheels.
Originally Posted by G35_Trinh
what is the stock WHP and WTQ on are cars anyway? I'm seeing a lot of different readings.
Old Jan 26, 2008 | 04:48 PM
  #138
IvoryPearl07G's Avatar
i have come to expect 260 to be a good average number...
like all have said, its a tool to use to see gains.
6wtq 8whp
Old Jan 26, 2008 | 04:57 PM
  #139
terrycs's Avatar
The official gains are 5.5 ft-lb torque and 8.3 HP on my car with auto trans. There were 3 runs of each setup averaged for these results, so I am confident of the official numbers. Of course, you statisticians may want a bigger n, but the results give a good indication of typical gains.
FI also weighed the stock exhaust at 62 pounds while I was there today. I was told the aluminized steel one on my car is 60 pounds, making them essentially the same. The SS will be a little lighter, but also not significantly. Let's put this in perspective ... a gallon of gas is about 7 pounds.
Old Jan 27, 2008 | 12:23 PM
  #140
terrycs's Avatar
Pictures with new Sebring mufflers installed:
Video of drive off:
Video of drive by:
The Sebring mufflers really bring down the sound when compared the Magnaflows. One can still tell by the sound outside that this is an aftermarket exhaust.
IMO, a great system just begging to be enhanced by HFCs. Those that want performance with subtle exhaust note would be happy with it as is. And those that want to take it to the next level with HFCs would benefit from lower combined noise output as well.
I'll take some peak dB readings as soon as I get the chance.
Old Jan 27, 2008 | 12:43 PM
  #141
rkdiddy's Avatar
Wow, looks and sounds great Terry.
How is the sound inside the car? It sounded like you had a little concern about the sound inside with the Magnaflow.
What do you think now?
Old Jan 27, 2008 | 01:21 PM
  #142
B L U E S L A T E's Avatar
Honda Accord
Sweet!!! I'm loving it even more now!
Have they tell you when they'll start producing these for us? Also, do you know if they're working on the HFC as well?
I'm getting the wheels this week, it'd be perfect if I can get everything done within this week. It is going to be MY Christmas this week. LOL
Old Jan 27, 2008 | 01:35 PM
  #143
TIRE_SMOKE96's Avatar
sounds good! With your attention to detail I cant wait to see what else you have planned!
Old Jan 27, 2008 | 02:43 PM
  #144
terrycs's Avatar
To me, it sounds ever so slightly louder than stock on the inside. If I had to scale the peak interior sound from 1 to 10 with 1 being stock and 10 being Magnaflow, I'd say it's about a 3 or 4. I'll post up any other comments from friends and family as they come up.
I'm happy with the way it sounds now, but since I have a little more headroom in the sound level department, I'm doing my income taxes right away ... I'm sure there will be enough there for HFCs. There should be significant gains there since the factory cats are usually the biggest restriction.
Old Jan 27, 2008 | 02:48 PM
  #145
terrycs's Avatar
You're welcome to come by anytime to take a listen. I'm sure others will want to hear your feedback as well since you've driven doth Stillen+HFC+Fujita and FI w/Magnaflow.
FI tells me HFCs are already available. Maybe they'll do a bundle pricing?
Old Jan 27, 2008 | 03:53 PM
  #146
kmuniz78's Avatar
Terry - If the Magnaflows are louder, they must have really been louder. I think the sound with the Sebrings is perfect!!!! Totally sold on this set-up now. Would be a great buy if FI did bundle the HFC's. Nice work!!!
Old Jan 27, 2008 | 04:24 PM
  #147
JMN's Avatar
JMN
Sounds great, HFC + Exhaust bundle would be awesome.
Old Jan 27, 2008 | 05:04 PM
  #148
solopresident's Avatar
teamsolo.net im-integline
Looks just like my tips!!! I love the sound and inside it is not to noticalbe at all under normal driving in my coupe. I use my bluetooth in the car no problems.
Old Jan 27, 2008 | 06:31 PM
  #149
terrycs's Avatar
Don't get me wrong ... and I hope I don't confuse things ... the Magnaflows were not that loud either. If I were younger, I'd probably like them too! Another reason to get one of you youngsters to review in person and comment. So when is the next local GTG?
Old Jan 27, 2008 | 06:32 PM
  #150
terrycs's Avatar
I still have to check out your pipes man! Aren't you going the HFC route?
