Anyone know how to Deactivate auto A/C on feature?
Old Mar 22, 2008 | 08:56 AM
rpm&my_G35's Avatar
Originally Posted by chilibowl
by what? 1-2 MPG? If youre that worried...trade in your G for a Honda Fit buddy .
Originally Posted by hyukki
Or a Toyota Prius.
Come on guys..remember the forum your in...you should, at the very least, be suggesting a Nissan product. Get a Versa
Old Mar 22, 2008 | 04:13 PM
dilettante's Avatar
My girlfriend has an Altima with the same situation. My frustration when I drive her car is not that the AC turns on automatically when using the defrost setting, but that it doesn't turn off automatically when I go back to using something other than defrost. As others have said, AC is not usually necessary for the other settings, so it would be nice if it turned itself off after turning itself on.
Old Dec 14, 2018 | 10:43 PM
909's Avatar
909
Your mom's boyfriend
Bump
Old Jan 23, 2019 | 04:31 PM
Joenavy85's Avatar
G35x Base
I'll bump it and rephrase the question. How can I make it so that I can recirculate the air with the A/C Off?
Old Oct 8, 2019 | 04:30 PM
Eric Marciniak's Avatar
G35X
My 08 G35X does this too but my moms 17 QX50 doesn't, hers can go through all the modes without the AC turning on at all.
Old Dec 3, 2019 | 10:49 PM
Red Shogun's Avatar
Garnet Ember G35X Sport EBC rotors LEDs GTR button Tail-as-Turn TBW undertray Alarm shock sensor
It's a good thing to have the AC run on occasion in the winter. It keeps the refrigerant oil passing through out the AC system, keeping seals from drying out and AC compressor bearings lubed. All you have to do is hit the AC button to turn the compressor off.
Oh and AC system does pull moisture out of the air....it does this by removing heat from the air (producing cold air) and condensing the moisture in the (now cold) evaporator core where it then drains out the drain pipe through the firewall.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Charchar66
Dec 19, 2019 01:17 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
