Best Mods for Hot weather
Old May 27, 2008 | 10:21 PM
snowcrossmxz's Avatar
might want to go with a little thicker oil. Like 10w30
Old May 28, 2008 | 02:16 AM
Defratos's Avatar
You're Despicable
Hmm, never thought of going with thicker oil, what would be the benefits of that in a hot climate exactly? and what is the standard oil that comes from the dealer in the states? The dealer here might already be using thicker oil (I'll have to check)
Old May 28, 2008 | 09:18 AM
I think its 5w30 in stock trim.
as the temp goes up, the oil gets thinner, as it goes down it gets thicker. im in NH so my car sees 90+ in the summer and negative numbers in the winter. so depending on the season I run different weights of oil. do I notice a difference in the car? nope.
But if you put a can of oil in the freezer and one on the driveway in the hot sun and compare the 2 after they have sat in the environment for a few hours it tends to make sense.
http://www.aa1car.com/library/oil_viscosity.htm
Old May 28, 2008 | 12:14 PM
B L U E S L A T E's Avatar
Honda Accord
Meth injection! hahaa
I mean... I don't think you'll find anything that is HELPFUL for the hot weather... :\
If your car has intakes, it'll just suck in more hot air. CF engine cover... prolly don't do anything at all. No spacer is available and I doubt it will soon and not that it will be helpful. Exhaust...... no.
So pretty much nothing you have listed above is useful for the hot weather.
Old May 28, 2008 | 12:36 PM
Defratos's Avatar
You're Despicable
I'll see how the car goes in June hopefully it won't overheat too much
Lol Thanks for that, pretty much straight to the point
Charchar66
Dec 19, 2019 01:17 PM
prinny
Nov 22, 2015 11:07 PM
hrdwirk1
Oct 2, 2015 06:34 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
