PICs from install of Garmin GVN-52
Old Jun 18, 2008 | 11:49 PM
PTP's Avatar
PTP
Just installed the Garmin GVN-52 like some other people here.
Everything is working well so far.
Took some pics along the way.
Posted at:
http://picasaweb.google.com/washingm...6/GVN52Install
Some are out of order but you get the gist.
Old Jun 18, 2008 | 11:56 PM
SunnY-D's Avatar
nice... i did my car a week ago also...
Old Jun 19, 2008 | 12:12 AM
G35Now!'s Avatar
Moderation-free
Nice write-up, thanks for posting.
Old Jun 19, 2008 | 09:00 AM
PTP's Avatar
PTP
http://www.youtube.com/watch?v=wTjTg8insOA
where did you mount the GPS sensor?
Old Jun 19, 2008 | 11:33 AM
SunnY-D's Avatar
i mounted the box under the glove compartment. the gps antenna was put in the lil space between end of the hood and the windshield wipers.
Old Jun 19, 2008 | 07:00 PM
rpm&my_G35's Avatar
How did you manage to get the GPS audio to cut the music playback when it is giving directions?
Are you using an MP3 player and piggy-backing the GPS through the RCA in the console or is it something else alltogether?
Are you happy with everything so far?
I have been considering this for a fairly long time. The bypass is already done.
Old Jun 19, 2008 | 11:19 PM
SunnY-D's Avatar
the music is playing through the ipod. theres a module that i setup wuth the gps, so normally, the ipod will play but when the gps has something to say, it will mute the ipod input and play the gps.
i wish they made the module for the entire cd/fm/aux thing. but its not created yet.
so far, the gps is pretty cool. it beats looking at a different screen for directions and different one for music. if u listen to ur ipod alot through aux, this is very good for you. if u listen to cd's, it might be a hassle to swtich back and forth. as for xm, u can get the xm wire and just add that to garmin and play it from there..
Old Jun 20, 2008 | 10:47 AM
rpm&my_G35's Avatar
I have my iPod connected via the Nissan module from everythingg35.com so it is displayed on screen via SAT. radio harness
More Questions (if you don't mind):
1. Am I correct in assuming that if you choose a destination, then switch back and forth between AUX(GPS) and radio/CD, that the GPS is still running and directing you toward your destination? If that the case I will probably install a GVN.
2. How good is the RF remote?
3. Can you add waypoint/locations or routes directly into the unit via a SD memory card?
4. Can you recommend a reliable and competitive priced place to purchase or did you purchase yours via private sale like on Ebay?
Thanks
Old Jun 20, 2008 | 11:45 AM
Wei's Avatar
Wei
i can probably answer some for you
1. yes, it's always on when the car is on
2. i have the unit in the trunk, and the rf remote works very well in the car, you just need to get used to inputting address thru the remote, if you're an expert texter via number keypad, it should be easy
3. probably, i've never actually taken it out after the initial map install...
4. ebay is where i got mine, there are lots of gray markets, not sure who is reliable...
Old Jun 20, 2008 | 12:12 PM
rpm&my_G35's Avatar
ty Wei!
Old Jul 12, 2008 | 05:52 PM
GA DIGG!'s Avatar
where did you get the garmin from and how much ?.... do you live cali?
Old Jul 12, 2008 | 09:46 PM
SunnY-D's Avatar
i got the garmin from online for $430~.... ebay ha it too... but google it and u'll find the prices.... and i live in ny
EnCr1pt3d
Jul 8, 2019 02:48 PM
WillisFL
Dec 29, 2016 08:56 AM
ResoG35Sedan
18 Inch
Nov 11, 2015 04:26 PM
MarcelDK
Aug 23, 2015 09:01 PM
EPG35
Aug 16, 2015 04:52 PM
