Serious heistation.
Old Nov 10, 2008 | 02:48 PM
ANMVQ's Avatar
Serious heistation.
Ok has happened 2-3 times. When I'm rolling in 1st gear very slow like 5mph if a gun if the car it hesitates something nasty almost like fuel cut. I accually lung foward in my seat. Has anyone had this issue before?? It also takes a good 2-3 seconds to downshift with I go WOT. I know these have a learing ECU and my wife drives it most oif the time and she never floors it I mean never. Could this be the issue. The car is freaking out when I dump it? there is NO CEL..
Old Nov 10, 2008 | 03:10 PM
mIKE's Avatar
I was gonna say VDC cutting power until i saw the AWD.
If you want a fast downshift, pop it into DS as u floor it.
Old Nov 10, 2008 | 03:16 PM
ANMVQ's Avatar
I have it in DS mode. I down shifts faster in D..
Old Nov 10, 2008 | 03:33 PM
Cyanide Ride's Avatar
I was going to say VDC as well.
I have an X, the only time that happens is when the VDC is on.
btw Rick, stop messing about on forums and call me back doggone it, Andy from from area code "780!!!"
Old Nov 10, 2008 | 03:38 PM
mIKE's Avatar
Try "rolling" it down instead of mashing it. DBW is programmed to prevent traction loss if at all possible.
Old Nov 10, 2008 | 04:14 PM
ANMVQ's Avatar
ok thanx Mike but kinda embarrassing as was almost beat of the line by a accord( 4Cyl) He was trying to cut me off as we were at a read light and the was a car parked in his lane on the other side of the intersection about 100 Ft way.
Old Nov 10, 2008 | 04:44 PM
agiraldo182's Avatar
AZNMQ I HAVE THE SAME PROBLEM with HFCS
Old Nov 10, 2008 | 04:50 PM
ANMVQ's Avatar
Why would these cause the car to hesitate like that is it fuel cut?? And are we the only ones with this problem.. Anyone else chime in??
Old Nov 10, 2008 | 05:31 PM
Bro. Call me and Ill explain the problem to see if you experience the same thing.
I sent you a PM.
Old Nov 11, 2008 | 08:49 AM
ANMVQ's Avatar
I just say it had to log off yesterday work got busy. I will call you this AM..
Old Nov 11, 2008 | 08:51 AM
ANMVQ's Avatar
Does anyone know if the ECU has to learn the new air flow?? The bog happens at 2k RPM's I check it last night. THe RMPS will rise right to 2k then stop like I hit a wall then it will pick up again..
Old Nov 11, 2008 | 09:57 AM
suby01's Avatar
turn vdc off and drive your car that way for some time meaning hard/flooring it. it happens i guess you call it the ecu needs to learn. drive it hard for a week, and youll see a difference.
Old Nov 11, 2008 | 10:34 AM
ANMVQ's Avatar
Ok will do I will try it, I will start today. I will also disconnect the battery to reset the ECU.. Thanx for the info..
Old Nov 11, 2008 | 11:01 AM
I dont think that'll work.
Our ECU is apprently tied into our A/T transmission.
Call me crazy but i have had the same problem with HFC's .... Hit me up and I'll discuss it
Old Nov 11, 2008 | 11:08 AM
ANMVQ's Avatar
Hey man just called you left a message just call me back at work when you can.. Thanx Mike
