No Cold Air
Old Oct 12, 2011 | 07:39 PM
vqsmile's Avatar
Originally Posted by bat6wc
My AC went out a month ago and had the compressor replaced under warranty. Under inspection, they also noticed my head gasket was leaking!!! Not good at all. They ended up replacing that as well.
How did they do that? Are you sure it was actually a head gasket and not a manifold or valve cover gasket?
Old Oct 12, 2011 | 07:57 PM
bat6wc's Avatar
How did they do what? Find the leak? I told them I was having idling issues. All the wording and documentation indicates head gasket. very weird i know. Im skeptical to believe head gasket as well.
Old Oct 12, 2011 | 08:02 PM
vqsmile's Avatar
Yeah . . . WOW. If it is indeed a HG, I think it's the first one I've heard of on an HR.
Old Jun 21, 2012 | 08:53 AM
supastar1568's Avatar
Back one year later. Finally set up the appointment to have a new compressor installed. I could go even longer (survived last summer when it was 103F, bumper to bumper traffic for 20 minutes on the way home), but the bearing on the compressor pulley is totally gone and sounds really awful. Started off very quiet, now it's loud as heck.
Old Sep 14, 2012 | 10:57 PM
G35XX's Avatar
Originally Posted by supastar1568
The troubleshooted and the AC compressor went bad.
They want $1200 installed.
The warranty is 4yr/60k miles, I've had it for 4yrs and 2 weeks and its only at 52k miles. I better have luck.
Try other independent shops and get a second opinion. They will fix it for cheaper.
Old Sep 14, 2012 | 11:26 PM
vqsmile's Avatar
Do you ever check the date of the posts you respond to to see if they are still relevant? This post is 14 months old. (07-23-2011, 09:39 AM to be exact)
I'm pretty sure he's gotten the issue resolved one way or another by now.
KruZZe
Feb 27, 2023 05:04 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
