Speedometer
Old Sep 24, 2011 | 08:11 PM
Loric76's Avatar
It could be just the print on gauge, or the needle calibration. If it's just that I can live with it (actually I wish I could forget it, would help keep my speed down lol). If it affects the odometer tho, there's a problem. And unfortunately whatever the problem is, the fix is to swap the cluster...not cheap.
Next time I'm out for a long enough drive I'll have to remember to reset the trip and use the GPS on my phone to track the distance, to see if the odometer is affected or not.
Old Sep 25, 2011 | 02:08 AM
kool_yaar's Avatar
^very likely and the most easily understandable reason.
Old Sep 26, 2011 | 01:18 PM
dave_stumph's Avatar
UPDATE: so the dealer called today and said that this was a know issue for 07 models but not 08's on the bulletin they get from tech department. He called and verified that it also includes 08 models as well and the fix is an updated cluster. He also said that if the speedo is off by 7.7% that this will correct the spedometer issue and the odometer is NOT effected by the spedo error. Now if it's off by more or less then the odometer will get recailabrated to correct milage. I'm taking the car in tonight. I'll also compare gps km to odometer km to verify it's in proper working condition? I'll post results when all is done.
Old Nov 1, 2011 | 09:56 PM
SOLVED!!
So the cluster was back ordered for a month. Brought it in yesterday and got the new cluster put in. Fixed the 7.7% speedo error. Now it reads perfect -1% witch is normal. The tbs # is ITB09-042A if anyone is interested. Should be able to get it fixed without warranty. The process is before they (dealership) get the cluster it's calibrated with your km at headquarters then sent to the dealer to install.
I told him my km on speedo a day before I brought it in and was at 60,580. Put an extra 90km till it got to the dealer (60,670km) Got it back at 60,580km.
Old Nov 1, 2011 | 10:02 PM
vqsmile's Avatar
Originally Posted by dave_stumph
SOLVED!!
Any mention of this being a Canadian vs.US model issue?
Old Nov 1, 2011 | 11:04 PM
Canadian35x's Avatar
Do you have the ICC? I had mine replaced too, but the ICC still reads the 7.7% off when the cluster and needle now read correctly.
Old Apr 4, 2012 | 01:36 AM
Race Track's Avatar
My '08 G35xS also has 7% speedo error at 100kph (Canadian vehicle). The error is consistently around 7% at higher and lower speeds. Interestingly, the trip meter is acurate to within 1 to 2% when checked against the measured kilometers on the 401. The average speed indication on the LCD display between tack and speedo seems accurate. In other words, the problem seems to be only in the mechanical speedometer. I read somewhere that there was a recall on the instrument clusters but can't find the article. Has anyone seen it?
Old Apr 4, 2012 | 10:49 AM
surfjax87's Avatar
Check this post a few above yours. It's a tsb, not a recall so if you're out of warranty it might be difficult to get the dealer to do any work under warranty. Have you ever reported this problem to your dealership?
SOLVED!!
Old Apr 4, 2012 | 11:51 AM
Race Track's Avatar
Thanks for this. Just bought this vehicle with 160K km on it, so no warrantee. Will let you know what happens.
Old Apr 4, 2012 | 02:00 PM
surfjax87's Avatar
If you just bought it, make sure the dealer understands that you believe the incorrect speedometer is a safety concern (which it is imho). More likely to get the ball rolling if the dealers sees it in this way instead of just a customer with some minor annoyance.
G35Lin
Feb 13, 2005 03:42 AM
stsurbrook
Mar 5, 2004 12:38 AM
Blade
Nov 21, 2003 07:39 PM
GurgenPB
Aug 2, 2003 03:49 AM
wreck
Jul 3, 2003 07:37 PM
