Wont Sense Car is in park!! Help
Old Nov 21, 2013 | 05:07 PM
2007HRCALI's Avatar
So my fiancé that it would be a good idea at about 5 MPH to grab the shift **** in the 2007 V36 5AT... she went back and forward I think it hit park, after a shout match I found out the car does not register its in park anymore...
-It says (Shift To Park) on dash although its in park.
-Do not need to push the brake in order to go from park to Drive
-If I take the Key Fob out of car theres one long continuous beep until fob is back in car. (I have to leave the fob in and lock/unlock with the key)
PLEAASE HELP
Is it the shift linkage? Is it inside the center console? brake switch?
Old Nov 21, 2013 | 05:42 PM
broke_as_ajoke's Avatar
i'm going to say the linkage is broke and the car doesn't know it's in park. I don't think it is in the console.. Just my two cent
Old Nov 21, 2013 | 07:48 PM
ChinkyChoy's Avatar
Think its time to get a new girl
Old Nov 21, 2013 | 08:40 PM
Lartytiejdke3's Avatar
Who won the shouting match
Old Nov 21, 2013 | 08:51 PM
2007HRCALI's Avatar
LOL came to a conclusion... Then went to the casino ended up a good night!!
So ill check on the tranny then for linkage to park.. but it tells me D for drive, R for reverse, and all numbers shifting manual just wont read park...
Old Nov 21, 2013 | 08:58 PM
Sounds like op beat her into silence
Old Nov 21, 2013 | 09:15 PM
KrazySouthG35's Avatar
Not sure if it could be the issue but try removing the shift **** and physically putting it in park with the little rod that allows it to change gears. You'll have more room to see what could be going on but chances are it's just not able to lock into park for some reason
Old Nov 23, 2013 | 07:12 PM
2007HRCALI's Avatar
oh one more thing... the little button on shifter does not "pop" out when in park, it stays as if im pulling it in.. maybe its the button not coming out in park and that's why it doesn't read its in park? it come out in other gears.
Old Nov 23, 2013 | 07:28 PM
Have you tried pulling the **** off like I suggested? I'm sure something is amiss inside there, you won't know until you check
Old Nov 25, 2013 | 09:13 PM
2007HRCALI's Avatar
I took the shift **** apart, put it back together and it registers that its in park now.. its a little stiff and sometimes does not register but I guess its better than not working at all... I think its something on the bottom of the plastic shaft under the **** that's binding up.
arora_g35
Apr 16, 2026 02:52 PM
chinee
Jun 10, 2024 07:48 PM
vmcarbuyer
Oct 12, 2019 12:42 PM
edwinisdumb15
SOCAL Meetings & Events
Jul 24, 2015 04:56 PM
ClwMike
Jul 23, 2015 12:55 PM
