V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
pulling the headliner
Old May 25, 2010 | 08:24 PM
lokig's Avatar
I got to get to my shark fin. Has anyone pulled down the headliner? Does it just pop right off? Do I need to do the sides first?
Old May 28, 2010 | 11:48 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Do you need to get to the connector or do you just need to remove the fin to paint or something?
The exterior fin is a cover that can be popped off the base, if that's what you need.
(haven't done it myself though)
Old May 28, 2010 | 12:26 PM
lokig's Avatar
need to remove it for a vinyl roof
Old May 28, 2010 | 12:35 PM
kool_yaar's Avatar
^ in that case popping the cover would be a better option like intgr said, this will allow you to let some excess vinyl go under the cover and look like a clean install, no need to go through the hassle of taking the headliner off which is said to be a pita.
Old May 28, 2010 | 12:45 PM
Bigd2k6's Avatar
Here's my DIY. It should be pretty similar for a sedan.
https://g35driver.com/forums/audio-v...r-removal.html
Old May 28, 2010 | 12:51 PM
lokig's Avatar
awesome thanks everyone
Old May 28, 2010 | 05:00 PM
LightsOut's Avatar
SIETESG
any good vinyl installer should be able to work around it.
my input
Old Jun 25, 2013 | 02:50 PM
jimmyjones's Avatar
What is the process to pop off the shark fin? I also want to install a vinyl overlay on my roof and want to pop off the shark fin to make this process a little easier/cleaner.
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Learned Hand
Oct 1, 2015 09:02 AM
