Rear tires wearing faster on outside?
Old Feb 20, 2007 | 01:52 PM
mc2's Avatar
mc2
I have a 2005 Coupe with OEM 19's. The rear tires are pretty much cooked and it's time for new ones at 19K miles, but i did notice that they wore faster on the outside than they are on the inside. I didnt really notice it before until recently.
What would cause this?
I have not had an alignment since i purchased the car, so I'll definately have one done once i get the new tires. but i just dont want my new tires to have any kind of uneven wear issues.
Front tires already get the crappy wear on the insides, so those probably have to be changed out now also
Old Feb 21, 2007 | 02:50 PM
Grumpy_G's Avatar
There's your problem.
Heavy acceleration in the corner or high cornering speed will wear out the outside pretty quick.
Old Mar 23, 2010 | 04:20 AM
nighthawk06's Avatar
did u change the new tires yet? How does it look now? Mine too, wore out uneven, i just noticed too... the outside wore more then the inside... front tires...
Old Mar 23, 2010 | 01:27 PM
4DGS's Avatar
I don't think either of these guys are on the forum anymore man.
You need to get your front adjusted. Could be a slight toe problems or you might be running a small amount of positive camber.
Toe is when the wheels do this / \ (if you were looking at the top of the car. Camber is when they do this / \ when looking at the back of the car. (this is positive camber \ / )
Old Mar 23, 2010 | 01:55 PM
Thanks for the info 4dgs... My car in bone stock, didn't lower it. I am still running on OEM tires with 25K miles.. Should I take it to the dealer and let them adjust it since I still have the warranty and they keep on bugging me about bring my car in for service. I guess I'll do that next week. Thanks again...
Old Mar 23, 2010 | 02:12 PM
4DGS's Avatar
Sure, but get a quote for the work first. Make sure they don't charge you at the *** for camber and toe adjustment. I'm unsure if they will fix it under warranty, IMO they should.
Old Mar 24, 2010 | 09:55 PM
rimshaker's Avatar
Get them to pricematch what a local nissan dealer would charge for alignment. Could save about $40.
Old Mar 24, 2010 | 09:57 PM
dofu's Avatar
20 Year Member
I don't think it's possible to get positive camber with a load on the suspension... maybe if the car was in the air, but otherwise, I don't see it happening.
Old Mar 25, 2010 | 01:43 AM
I called around, pepboys charges $75, wheels world charges $70, infiniti dealer won't cover under warranty and they charge $60 with the purchase of 4 tires, Kumho charges $40... I guess i'll bring it there tomorrow morning. My sister, gf, and bro changed their tires there too. Gona see what happen tomorrow...
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
tiguy99
Mar 1, 2016 11:42 AM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
wuppiedog
Aug 7, 2015 11:16 AM
nascarbuff17
Jul 16, 2015 10:23 AM
