How long will my rear tires last?
Old 07-02-2007, 10:05 AM
flnsx's Avatar
Anyone know the average miles the rears on an 06 will last?
I think they are all the same brand and model...
Old 07-02-2007, 10:08 AM
izmir41500's Avatar
G35driver Addict
i got almost 25k out of mine.
Old 07-02-2007, 10:15 AM
Hi-TechG35's Avatar
Location: Pothole Central and still ridin slammed...Boston
^+1. I got like 24k and some change before I started noticing the annoying noise increase level on mine. Then the tread was done.
Old 07-02-2007, 10:21 AM
JOKER's Avatar
CLUB MODERATOR
Yep same here.
I got almost 30k out of my. But they looked like slicks
Old 07-02-2007, 12:28 PM
LjN_728's Avatar
What are you on...17" or 19"? If you got 19", Potenza, I'm on 31k miles with about 10k more left to go.
Old 07-02-2007, 02:08 PM
filthyg35's Avatar
Originally Posted by JOKER
Yep same here.
ha ha....I got 36, also looked like racing slicks....it was pretty cool being able to smoke the tires real easy and impress everyone...they thought it was the motor or something...ha ha
Old 07-02-2007, 02:12 PM
JOKER's Avatar
CLUB MODERATOR
mine came to be slicks in NOVEMBER during snow times.
So I saved lots of $ going ice scatting. I just did it in my car.
Old 07-02-2007, 02:13 PM
jtrudeau's Avatar
I got 32K out of the Pilot Sports but the rears looked like slicks when I changed them, so probably should have been 28K. I now have about 6K on the BFGoodrich GForce TA KDW and I really like these tires, good grip, but they "chirp" alot.
Old 07-02-2007, 02:15 PM
Beebo's Avatar
are the tires the same as 05 19's if so i have about 33k and some on the rears i had to put new fronts on first but the rears do look like slicks
Old 07-02-2007, 02:44 PM
Silver350GT's Avatar
I will be lucky if I get 20K out of Toyo's but I drive it like a stole it.
Old 07-02-2007, 02:54 PM
JOKER's Avatar
CLUB MODERATOR
^Toyos do suck that way.
I killed my first set in 10k (it was almost 10k used when I bought them with rims)
Old 07-02-2007, 02:56 PM
Skaterbasist's Avatar
Retired SuperMod
Hmmmm... I'll be lucky if I get 15k out of my stock tires, considering I've done almost 75 runs at the drag strip & many canyon runs
Old 07-02-2007, 03:13 PM
bocatrip's Avatar
If the owner is diligent to changing out the rear tires when the tread reaches the "wear bar", most tires will not go much further than 18,000 miles. Since our rear tires wear primarily in the middle treads, the visual inspection is deceiving, as the outer treads will wear slower and have more tread. Bottom line is, for all those that are getting those high numbers out of the rears is because you are going past the 2/32 mark of the wear bars and in actuality, the tires were not safe at that point.
Old 07-02-2007, 03:53 PM
alphamatt's Avatar
well it really depends how you drive, i like to roll into puddles and do the rattle snake.
Old 07-02-2007, 03:58 PM
izmir41500's Avatar
G35driver Addict
yep. i'm down that far, and yes i know it is not safe which is why i have new wheels and tires i need to put on.
Quick Reply: How long will my rear tires last?
