Biggest Tire Size On OEM 19's
Originally Posted by Klubbheads
stock profile is 40, it looks ugly IMO. 35 series looks much nicer especially on a lowered car.
40? thats the first ive seen that... what IYO is the advantage? stance? i will be lowering, wouldnt it cause rubbing? ill have a 265 in the rear
Sorry OP for da off topic swerve.. That was too funny to pass up
You realize that the aspect ratio of a tire is a percentage right? A 285/35/19 has a larger sidewall than a 245/40/19. I'll take function before form any day, messing with the odometer/speedometer readings significantly for looks is not a good idea IMO.
255/40/19 is wider than stock and is only 3mm taller than stock, which is why I recommend that size. A 265 rear is a difficult size because 40 series sidewalls a too tall compared to stock, and 35 series sidewalls are too short, either way to are going to throw off your odometer/speedoemeter readings. So 265/35/19 would be the better size probably, but still not optimal
