Tire and Wheel Setup
Old Dec 22, 2007 | 07:42 PM
sspunisher's Avatar
I have a 2003 G35 Sedan
I want 19" Rims but I have no clue how to mix and match the tires and the wheels.
Here are some things that I want/don't want in my tire/wheel setup.
1). I want Staggard tires.
2). I'd like a high performance tire like a Falken if possible.
3). I want Summer tires. I have winter tires so I don't want all weather tires.
4. I don't want to roll my fenders.
I know there's a lot of different possibilities and a lot are personal preference, but if someone can give me 2 or 3 common set up options and the positives and negatives of each I'd appreciate because all these options that I have are overwhelming.
Also advice on the width of tires would be helpful.
Old Dec 22, 2007 | 07:44 PM
ttrank's Avatar
Grocery getter
If you want 19's and have a sedan I would go with 8.5's ~+35-40 up front and 10's ~+45 in the rear and roll your fenders.
With that combo you can run 245/35 front and 275/30 rear tires.
Nitto 555's, Falken FK452, Toyo T1R, Kumho SPT are good tire choices along with a dozen or so others.
Old Dec 22, 2007 | 08:23 PM
sspunisher's Avatar
What do you suggest if i DONT want to roll my fenders?
Old Dec 22, 2007 | 09:13 PM
Gfan's Avatar
I know this is a dumb question but what do you mean by rolling fenders? Is it when you make them a bit shorter so there is less rubbing?
Thanks!
Old Dec 22, 2007 | 10:08 PM
sspunisher's Avatar
What do you mean by 8.5 and 10s in the back?
Old Dec 22, 2007 | 10:13 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Is the car lowered? if so, how much?
-GP-
Old Dec 22, 2007 | 10:25 PM
Texasscout's Avatar
Thanks!
It's when you take a gizmo and "fold back the inside lip (flange) of the fender to make more room for the tire under the fender.
Old Dec 22, 2007 | 10:27 PM
Texasscout's Avatar
That is the width of the rim.
The "offset" is the critical part here, you put the wrong offset and your tires will rub on the underside fenders (too much + offset) or the suspension (too much - offset)
http://www.wheelsmaster.com/rt_specs.jsp
Old Dec 22, 2007 | 10:36 PM
Texasscout's Avatar
Old Dec 22, 2007 | 11:41 PM
Gfan's Avatar
Thanks man. Thats what I thought as I stated in my question but i just wanted to clarify.
Thanks Again!
Old Dec 23, 2007 | 09:21 AM
Gilley's Avatar
Why do people have such a problem with rolling the fenders and installing camber kits? If you're going to modify a car, do what needs to be done to do it the correct way.
Old Dec 23, 2007 | 10:41 AM
sspunisher's Avatar
Because I don't know how to do it, where to do it, and how much it will all cost. It's hard enough trying to get the info on how to match the tires and the wheels in one simple reply.
Old Dec 23, 2007 | 07:44 PM
Gilley's Avatar
Ask questions about how to do it, where to do it, and how much it will cost. That's how we all learn. I rolled my rear fenders in my garage with a rubber mallot and a heat gun, using a lot of light blows to gently bend the lip over.
bu villain
19 Inch
Nov 15, 2015 09:23 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
