Bodyshop Putting On 245/35/19 Pirelli All-Seasons: What to Do About Rear Tires?
Old Nov 19, 2008 | 01:11 PM
M.J.H.'s Avatar
Question Bodyshop Putting On 245/35/19 Pirelli All-Seasons: What to Do About Rear Tires?
My bodyshop is replacing my front tires with some Pirelli P-Zero Nero all-season tires in 245/35/19 the size I requested. Now I absolutely LOVE these tires I've had them on previous vehicles but I noticed that the Pirelli's are not made in the 255/35/19 size the typical recommended tire size for the rear.
So I can either run 245/35/19 in the rear just like the front in the same exact brand and tire, or I can go extreme and run 275/30/19 but I think this would be a little stupid looking since I already have 20mm spacer in the rear and the wheel is only 8.5" wide.
I really want to try avoid mixing up tire brands if possible, but I'm shocked Pirelli P-Zero Nero M&S is not even made in 245/40/19.
Advice?
Old Nov 19, 2008 | 01:34 PM
redlude97's Avatar
You should be looking for 255/40/19 rear. Do not under any circumstances run a 275 in the rear
Old Nov 19, 2008 | 01:41 PM
M.J.H.'s Avatar
But with the Pireli P-Zero Nero M&S they do not offer that tire in the 255/40/19 size or the 255/35/19 size. Is it a bad idea to run a different brand front and rear? I was always told that it would negatively affect the handling that's the only reason I'm hesitant. Is 245/35/19 a bad idea to run in the rear?
Old Nov 19, 2008 | 01:46 PM
redlude97's Avatar
why not run a different brand of tire then? There are other all-season tires made in the correct sizes front and rear
Old Nov 19, 2008 | 01:52 PM
M.J.H.'s Avatar
Oh, yeah I know and that's kind of my question, sorry for the confusion. I was thinking about running 255/35/19 Michelin Pilot all-season tires in the rear or is there a reason to go with 255/40/19 tires? I was trying to stay consistent with 35 series front and rear.
Old Nov 19, 2008 | 02:03 PM
redlude97's Avatar
I would run the michelins all around, and you should run the 255/40/19 since its much closer to the OEM diameter than the 255/35/19
Old Nov 19, 2008 | 04:31 PM
M.J.H.'s Avatar
I am trying to change my order but honestly now it maybe too late.
Old Nov 19, 2008 | 06:38 PM
Don@TireOption's Avatar
Do your research and then buy man!
Old Nov 20, 2008 | 09:37 AM
M.J.H.'s Avatar
I agree but unfortunately it's too late now and there's nothing that I can do about it. I have 245/35 Pirelli P-Zero Nero M&S tires up front going on and I need to pick up some all-season rear tires I'm thinking 255/40/19 most likely at this point.
Old Nov 20, 2008 | 07:44 PM
kasher_khan's Avatar
Sorry if I am hijacking the thread but have the exact same issue
I have a 2006 G35 Coupe (6MT) all factory options including RAS. My stock tires on the 19" are almost done (BridgeStones).
I was considering plus sizing since I am looking at Michelin Pilot Sport AS as well.
Stock tires F 225/40/19 R 245/20/19
The only size they have the tire I want in that I can think of would work is
F 245/35/19 R 255/35/19
Can I have change the rear to 255/40/19 (that would make the diameter diff between front and ear too much. How important is the origional staggered ratio? Should I really try to find tires in the 235/40/19 (F) 255/40/19 (R)
So confused... I have tried all kinds of caculators on line.
OP - DId you get a chance to have your tires put on? How are they workin out?
Any advice would be great !
THANKS...
vitamin.v
Nov 7, 2019 06:10 PM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
nascarbuff17
Jul 16, 2015 10:23 AM
Jadenkid22
Jul 14, 2015 12:33 AM
