Brembo brake upgrade on non 6MT?
Old Jun 10, 2004 | 01:18 AM
Lord_Bricks's Avatar
i have tried searching for this answer and couldnt come up with one..
i have the 5AT with tire/wheel upgrade - could i purchase the brembo rotors,pads, etc and put them on my car?
thanks in advance for any info!
Old Jun 10, 2004 | 10:40 AM
R2 V35's Avatar
Re: Brembo brake upgrade on non 6MT?
Yep, it's been done...I've seen it on a Sedan and a Coupe. But, you gotta make sure your wheels are made to clear aftermarket/brembos brake kit
Peace!
Reggie
6MT Ivory/Willow>>Nismo OEM Kit>>Premium Package>>XM
"Is simplicity best or simply the easiest"
Old Jun 10, 2004 | 12:09 PM
thanks for the info!
Old Jun 10, 2004 | 02:59 PM
GoSooners's Avatar
I hope you're referring to purchasing the Grand Turismo Brembo kit because I think if you purchased the Brembo calipers and rotors that come with a 6MT from Infiniti, it's about the same price. Hence, you get better calipers and bigger rotors.
Black on Black 5AT Coupe, Navi
Falken Koblenz 19x8.5 F 19x9.5 R
Falken FK-451 245/35 F 285/35 R
HKS Legamax Exhaust
350Z Duct
Stillen Hi Flow
7 Wire Hypergrounding Kit
Old Jun 10, 2004 | 05:15 PM
al503's Avatar
I think he's talking about the stock 6mt brembos and not the GT aftermarket kit. The GT kit will not fit under the 18" stock wheels.
Old Jun 11, 2004 | 11:09 AM
Sportcoupe35's Avatar
How much would the full 6MT Brembo kit go for?
2004 Ivory Pearl Sports Coupe
Old Jun 11, 2004 | 11:32 AM
hksjza70's Avatar
I was asking the same question re. the oem brembo kit, for fitment on the sedan. . . true the GT kit is better, however, if the availability is there, for approx. the same cost you'd be stepping into a 4 wheel kit. I'm doing my research as well . . questions I have . .
1. will I even be able to find an oem brembo set in decent shape?
2. what is the installation like? any bracket fabrication, cutting of the dust guard, etc?
3. does the master cylinder size match the recommended piston size for non brembo equipped cars? or is there some modification there?
I mean if all those factors are against you, I'd much rather opt for a GT kit or Stoptech alternative, everything is there for you, instal and go . . I think I've grown out of the 'fab it up and make it work' stage of my life . . plus the other beauty is . . if you're not into it, the dealer can still service them!
Anybody have any insight?
Thanks
Old Jun 11, 2004 | 11:59 AM
al503's Avatar
OEM brembos come up every once in a while in the classified on my350z.com. Depending on the condition (miles, tracked or not), they tend to range in price around $2000 to $2500 (for all four corners.) For instance, I'm planning on upgrading to a BBK and my brembos have less than 7K on them. 90% highway miles and I haven't even invoked the ABS yet. I took a straight edge to the rotors and they show no wear on the borders at the ends of the pads. I could probably get on the upper end of the price range but I don't know if I'll sell them or not.
I think you would have to be patient and spend a premium $2500 to get a set that has low miles and has never been tracked.
I don't think there is any cutting necessary in the fronts. However, you will need to cut the 'dust guard' in the rear. Zimbo bought $1.99's brembos and installed them on his sedan.
Couldn't tell you about the cylinder size etc. However, if the aftermarket kits use the stock cylinder etc., the stock brembos should work fine also.
Frankieg35
Mar 20, 2016 09:42 PM
RA081024
Aug 18, 2015 07:03 AM
Popes
Jul 29, 2015 05:07 PM
Karnicle
Jul 23, 2015 05:08 AM
vstypicals
Jul 20, 2015 10:55 PM
