aggressive fitment - how do I make this work? (pics)
Old Jan 17, 2009 | 08:47 PM
patman530's Avatar
I just got 25mm spacers, and the look is right, but with my current setup, it rubs too much. I think my options are to either run a smaller spacer (not preferred), run more stretched tires, roll the fenders even more than they are currently rolled, raise up the rear a little (not preferred). I already have quite a bit of negative camber from the car being slammed, so I don't think adjusting camber more negatively would be an option.
I am leaning towards rolling the fenders more, but I'm not sure if it would be too much. For those who have experienced this, can you please give me some advice?
Specs: Work VS-XX
19x10.5 +29 Odisk Toyo T1R 275/35/19, 25mm spacer
on Tein Flex coilovers, spring mount mod, 1 spring perch removed, lowest setting
Thanks
Without spacers:
Old Jan 17, 2009 | 08:54 PM
GreenGoblin's Avatar
The goblin resurrection
need more info what are the wheel sizes, offsets, tire sizes etc...
Old Jan 17, 2009 | 08:59 PM
patman530's Avatar
Edited original post.
Old Jan 17, 2009 | 09:15 PM
gary c's Avatar
Try using a little common since, if the spacers are to big rather than replacing
the tires or damaging the wheel wells further get smaller spacers. How much
different could it look with 1/2" smaller spacers, sometimes too aggressive
isn't smart!
Gary
Old Jan 17, 2009 | 09:19 PM
patman530's Avatar
^^ just going for the look. smaller spacers would be my last resort if all else fails
Old Jan 17, 2009 | 09:26 PM
so you would now be a +4, I would suggest. Rolling your fenders paper thin, and going to a more stretched tire 265/30 19 maybe.
Old Jan 17, 2009 | 09:30 PM
Cost a G's Avatar
Get smaller tires. I would go with 255/35 19
Old Jan 18, 2009 | 01:52 AM
Bashar368's Avatar
camber
Old Jan 18, 2009 | 09:13 AM
str8dum1's Avatar
+1, run your camber out. only takes a minute to do and is free.
Old Jan 18, 2009 | 09:45 AM
deeznutts23's Avatar
camberrr...or drop 10mm on the spacers...
Old Jan 18, 2009 | 09:53 AM
escobar929's Avatar
+1
whats your camber at?
i would say also try out a 20mm instead of a 25mm
Old Jan 18, 2009 | 10:02 AM
Ghayes23's Avatar
I think you could run some more negative camber.
Old Jan 18, 2009 | 10:41 AM
STCLAIRWEST's Avatar
Roll your fenders
Old Jan 18, 2009 | 12:40 PM
V35 Skyline GT's Avatar
6MT Coupe
Try rolling more if possible. Mine are rolled almost flat.
And up your dampener setting. Tein Flex are adjustable dampers right? (sry I'm a Cusco guy so don't know)
Or as mentioned, less aggressive spacers.
275's already stretched enough imo with using 19x10.5's.
Nice look...love it.
Old Jan 18, 2009 | 12:43 PM
patman530's Avatar
Thanks for the input guys. I will probably need to dial in more negative camber and roll my fenders more. I'll post pics when I get this resolved.
