TPMS and VDC question
Old Feb 23, 2009 | 06:19 PM
optimus310's Avatar
Sorry if this has been posted before. I searched but can't find any specific info to my problem.
Anyway I recently replaced the 18s on my 04 Coupe with the OEM 19's from the 05+. I got new rear tires and used the TPMS that were already on the 19s.
A week after that I took the car for a trip on a very fun road, and about 30-40 minutes into the road my TPMS light came on. I stopped to check all the tires and they were all at around 37-38PSI. I kept driving and my traction control started doing weird things and randomly thinking that my car was spinning out of control. It felt as if I had no control of the car.
Could this be related to the TPMS from the other wheels?
Do I have to program these to my car?
On the way back the TPMS light came on again, so I turned off the VDC and everything was fine.
Old Feb 23, 2009 | 07:02 PM
Klubbheads's Avatar
The low pressure light used to come on on my car with the OEM 17s and with OEM 19s after 30 minutes of highway driving. I never took it to the dealer for that problem (always forgot). As far as the VDC, i have no clue because my VDC was never on for more than 30 seconds in my 4 years of ownership. But i used to have the tire pressure problem as well after certain period of highway driving.
I don't know the solution so my post was probably useless but nonetheless i did have that problem.
Old Feb 23, 2009 | 08:46 PM
Mustang5L5's Avatar
What are your tire sizes front and rear?
Old Feb 23, 2009 | 09:00 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
If these were not the ones already on your car, they need to be programmed to the system.
Old Feb 24, 2009 | 01:18 AM
optimus310's Avatar
fronts are 225/40/19
rears are 245/40/19
Old Feb 24, 2009 | 01:19 AM
optimus310's Avatar
mmm I guess I would need the stealership to take care of that
Old Feb 25, 2009 | 03:56 PM
Mustang5L5's Avatar
Darn, i missed that comment.
Yes, you need to reprogram the sensors to the car
Old Feb 26, 2009 | 09:49 AM
QuadCam's Avatar
anyone know how to reprogram the system?
Old Mar 3, 2009 | 04:23 PM
1992_eg's Avatar
i have the same issue
Old Mar 3, 2009 | 10:50 PM
luigi38's Avatar
the dealer has to do it.
Unless you have the INfiniti software and cable for the G35
Old Mar 4, 2009 | 08:53 PM
zx10r_646's Avatar
I was able to reset and have the tpms relearn a different set of wheel sensors without any special tools. Please refer to Post 18 in:
https://g35driver.com/forums/canada/...-wheels-2.html
Larry
Old Mar 4, 2009 | 09:23 PM
luigi38's Avatar
thanks for the info
One question where do u connect both sides of the cable you describe ? also do u ground the cable or just leave it hanging.
thanks
DOMO
Old Mar 4, 2009 | 09:45 PM
zx10r_646's Avatar
The wire is grounded to set the tpms into relearning mode. The other end of the wire is plugged into the connector (as per OBD3Solution Blog instructions). Once the relearning process is completed, just disconnected the wire from ground and let it float or remove the wire entirely.
Larry
Mry
Mar 3, 2023 01:03 AM
Frankieg35
Sep 9, 2015 12:17 AM
Wayne9011
Aug 17, 2015 01:24 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Wayne9011
Jul 27, 2015 11:25 AM
