Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Apr 13, 2011 | 10:15 AM
  #1741
Deezflip's Avatar
Originally Posted by chatt350gt
well to solve the tire to fender gap you can always add a spacer or get a slightly bigger tire..=] my vote is for spacer lol especially if you run natural camber and space it out...mmmm haha
^nah man, fender gap, spacers or tire size isn't the problem. I was just wondering how you'll be able to ride with a poke and mild camber, like the one in the pic, without the rim banging up on the fender.
Old Apr 13, 2011 | 10:51 AM
  #1742
ptd23's Avatar
i was gonna try to change the front offsets of my vs-xx's coming in from 20x9.5 +0 to -13. is that too aggressive for daily driving?
Old Apr 13, 2011 | 11:21 AM
  #1743
chatt350gt's Avatar
Yes I know that was your question..I thought it was answered...a stiff dampened suspension..and careful driving =)I was just giving a solution since you had brought up the whole rim cambered to fender on others cars and how johnnys tire would have gap if he cambered it in and would have to space it out..that's all..many people drive lower than that with fender almost touching rim and do it daily..with no fender damage..its just a change of driving habitand a good suspension....
And about the vs-xx bringing it out to -13 would be sick but you will definitely have to do some tire stretching,camber and pulling..if you look up the lakeshore g35 coupe on white varrstoens he's running -13 front and -18 rear on same size wheels with a 215 front and 235 rear..in my opinion..perrrrfect..and he daily drives it with tire sidewall touching fender..slammed..I know cause I talked to him..probably not practical for daily but depends on where you go and how you drive..doable though.
Old Apr 13, 2011 | 11:26 AM
  #1744
ptd23's Avatar
so i wouldnt be able to run 235/255 35 series on 20x9.5 -13 20x11 -4, and i would need the camber kit to get more negative camber correct?
Old Apr 14, 2011 | 12:10 AM
  #1745
D.Reaper's Avatar
having an issue with rubbing, but fenders have been rolled and pinched almost paper thin on a sedan...i think what is rubbing is either the front screw or back screw (middle screw and clip removed) or both...can i just take out front screw and clip? dont want my fender liner to hang and eventually get ripped off
Old Apr 14, 2011 | 12:18 AM
  #1746
chatt350gt's Avatar
1 guy is running a 225 front on a 9.5 with -6 offset with rolling/pulling and shave but looks like he has some space to go wider..johhnybeastfoo was running a 9.5 front with -10 offset on 235 with just fender rolling...i dont know why the difference..guess they have different camber settings which may be why 1 is more aggressive and required more work..maybe someone with these/close to these offsets can chime in.
and yes i would get a camber kit just to be able to adjust...but id see how it sits before you get/install camber kit cause natural camber might be enough to clear with fender work..
Old Apr 14, 2011 | 12:28 AM
  #1747
ptd23's Avatar
yeah im gonnna wait to see what others have to say. but i might just leave my order as it is and throw 10mm spacers on all around.
Old Apr 14, 2011 | 03:54 AM
  #1748
Popgoesatire's Avatar
I want to see a G35 Coupe stock with 20's (post em)
I am wanting to buy 20's for my coupe and was wondering what setup I could use without rubbing or rolling fenders.Im not lowered and want to see what it looks like without. I wanted to put 245/35/20 in front and 275/30/20 in rear. If you have this setup show me some pictures. Thanks.
Old Apr 14, 2011 | 04:03 AM
  #1749
Want my wheels to fit like this.
Originally Posted by Pepper
I finally got my wheels back from chroming the barrels. They are Volk GT-S 19x9.5 +2 (15mm spacer) 235/35/19 & 19x10.5 +3 (15mm spacer) 255/35/19 (Toyo T1R) . Im on Tein Flex and the rears are maxed out. I need another 1/2" - 3/4" lower. Should I cut the spring mount?? Suggestions?
This is sick! LOVE IT!
Old Apr 14, 2011 | 10:08 AM
  #1750
Deezflip's Avatar
^ if you want your wheels to look like that, you'll have to roll fenders and lower your car. There's no other possible way of achieving that look. FYI, he's now currently at -3mm front, and -2 rear. ..sick isn't it?
Old Apr 14, 2011 | 10:35 AM
  #1751
I love those wheels too ....damnn. Drooling!
Old Apr 14, 2011 | 12:44 PM
  #1752
The X Factor's Avatar
Is it possible to run the 07/08 split 5-spoke wheels on a 1st gen AWD? I'm thinking I might try and put some one eventually, but I don't wanna tear apart my AWD system haha.
Old Apr 14, 2011 | 12:53 PM
  #1753
chatt350gt's Avatar
Like deesflip said no other way but stretching tires..fender roll and lowwwww...if you don't want to roll fenders you'll have to run around a +22 offset on the normal 9.5/10.5 setup..and run around a 245/275 tire setup..
Old Apr 14, 2011 | 07:17 PM
  #1754
05Scoobyroo's Avatar
I have a 20x10 +20 in the rear, with a 275/30/20, lowered on Tanabe Coilovers. The way the coilovers are set now, there is about 1.50 inches so far, and the coilovers have about 2 more inches to go in the rear. If I lower the car down and more, will I need to roll rear fenders?
Old Apr 15, 2011 | 03:20 AM
  #1755
salamsg35's Avatar
Hello guys.. ok I'm trying to get Conceptone RS8 Wheels. they come only in 20s i was looking to get 19s, but they dont come in 19 for a coupe.
So If i go with 20 8.5 F, 20 10.5 R.. what tires and offset should i get so i dont Rubbb At All my G is not lowerd
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
