Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Mar 29, 2012 | 02:15 AM
  #3091
susu510's Avatar
Sweet, Nice set up you had, how lOw were you all around?
Old Mar 29, 2012 | 02:19 AM
  #3092
Sylvan lake V35's Avatar
Not sure that was 4-5 years ago.
Old Mar 29, 2012 | 08:38 AM
  #3093
pghg35sedan's Avatar
19x9.5 front 19x10.5 rear both +24 offsets. What's gotta be done to fit an 04 G35 sedan just fender roll. And some camber all around or would I need a pull?
Old Mar 29, 2012 | 03:28 PM
  #3094
4DGS's Avatar
Roll the rear flat, pull fender liner hardware out up front. Run a 15-20mm spacer up front and 225/35 and 245/35, natural camber from a 3" drop and you're good to go.
Old Mar 29, 2012 | 09:38 PM
  #3095
scarface514's Avatar
i have a 03 sedan is the tire size the same ? i got 20" 8.5 n 10 in the back
Old Mar 30, 2012 | 01:58 PM
  #3096
4DGS's Avatar
Same as what?
Old Mar 31, 2012 | 04:07 AM
  #3097
wussupb0o's Avatar
Work T1S
19x9+25 front, tires = 225/35/19
19x10.5+30 rear, tires = 255/35/19
Planning on getting 25mm spacers for the front and 30mm for the rear. Will the wheels sit flush after the spacers or will it still tuck on a coupe? Planning to go as low as i can on with the coils after putting the works on. I wanna figure this out before driving 3 hours away to pick them up.
Thanks in advance.
Old Mar 31, 2012 | 02:11 PM
  #3098
Setko's-G35's Avatar
Stretch
ok guys. i am getting the XXR 526 Chromium black in 20x9 front and 20x11 rear. I want to stretch my tires like so...Name:  DSCN1196.jpg
What size should i get to get this affect?
by that i mean where you can see the lip from the wheel from the rear of the car like in this pic.
My idea was to go with 225/30/20 front
255/30/20 rear
Old Mar 31, 2012 | 09:09 PM
  #3099
susu510's Avatar
A friend of mine is running a similar setup on his, hes using 225/40/19 front and 245/40/19 rear on 19x11 and 19x10 Name:  g37.jpg
Old Mar 31, 2012 | 10:10 PM
  #3100
Nice. love it. i wonder how that translates to 20" rims.
Old Mar 31, 2012 | 10:45 PM
  #3101
Old Apr 1, 2012 | 01:47 AM
  #3102
muhtish's Avatar
Why is this happening???
OK I finally got my car lowered and after the alignment this is what I have encountered:
My passenger front wheel is pretty flush with the fender, but my driver front wheel sticks out more by about 1/2''. I have SPC camber arms that replaced OEM. What could cause this?
See pictures below.
Size:  88.8 KBName:  03271952.jpg
I thought maybe it was because I didn't have an even drop, but even after adjusting my suspension to EXACT specs, it looks like this.
Old Apr 1, 2012 | 10:37 AM
  #3103
I have the same setup as you(SPC). did you make sure when you did the drop or the install that the piece under the joint is the same as on the other side. In this pic it would be the piece on top of that red ball, but under the top of it.it is a gold piece, that you can turn to get negative and positive adjustment's in your front camber. The problem may be that that is as far as they could go on the alignment rack. Make sure that, that gold piece is in the same position as the other one. Sorry for the confusing explanation.
Old Apr 1, 2012 | 01:30 PM
  #3104
muhtish's Avatar
I will have to check and see. Honestly, I don't remember messing with it, but who knows, it might have came in from the factory with a different setting on each arm.
Thank you for the advice.
Old Apr 1, 2012 | 05:46 PM
  #3105
dominate's Avatar
On a 04 Sedan, how would 19x9.5 +30 all around fit? Assuming I drop and have camber kits, is there a need to modify fenders? If so which ones? Would 9.5 front look odd in the front in the first place? Looking to keep negative camber as close to stock as possible.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
