Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Oct 6, 2009 | 10:22 PM
  #316
tom's_Z's Avatar
Originally Posted by ShanesG
Tom you can run a 25/30 for sure, you will need to get your rears rolled and your front fender tab will need to be bent up or cut off also a slight roll of the front wouldn't hurt either.
Shane,
Thanks for the info, and mounted the spacers, BUT rubbing on the rear passenger side......may have to get a camber kit.
Any ideas?
Old Oct 6, 2009 | 10:30 PM
  #317
eurodre's Avatar
^^roll you fenders or even do a pull
don't see the need for a camber kit in order to prevent RUBBING, as without a camber kit you have MORE negative camber which reduces the rubbing
Old Oct 7, 2009 | 02:30 PM
  #318
tom's_Z's Avatar
May have to do a pull, as the fenders are already rolled.....
Old Oct 7, 2009 | 03:00 PM
  #319
eurodre's Avatar
^^go for it, its honestly not a big deal just get someone who knows what they are doing
Old Oct 7, 2009 | 03:50 PM
  #320
ShanesG's Avatar
did they roll the fender all the way flat, whoever did it prob rolled one side more than the other!
Old Oct 7, 2009 | 06:03 PM
  #321
HXS's Avatar
HXS
eurodre and shane:
20X9.5 +4 w/ 245/30 falken
20X10.5 +0 w/ 275/30 falken
dropped on 350Z tanabe GF210, -1.8 camber front and -1.5 camber rear
rear fenders rolled
will i rub?
thanks!
Old Oct 7, 2009 | 06:40 PM
  #322
eurodre's Avatar
^^i would roll you front fenders as well, just to prevent it from rubbing when u go into dips on freeway, the rear i would do a pull, but you can always test fit them and see from there, unless there are some constraints to you doing so
Old Oct 7, 2009 | 08:42 PM
  #323
ShanesG's Avatar
Yes you will rub especially with that camber! If your fenders are SUPER FLAT you can prob fit the rears with about 2.5 camber fronts will also rub mostly on turning slowliy and you make hit the fender metal where the bumper and fender attach so try bending that up!
Old Oct 7, 2009 | 09:22 PM
  #324
eurodre's Avatar
yah for that piece its pretty much just custom work on your part, you can find a way to bend that piece and pull the fender out a little, because thats were im rubbing as well
Old Oct 7, 2009 | 09:52 PM
  #325
HXS's Avatar
HXS
thanks guys... looks like a bit too much headache at the moment.
maybe i'll postpone the new wheels...
Old Oct 7, 2009 | 10:24 PM
  #326
eurodre's Avatar
^^oh not at all man, once you got it figured out its not too bad, just find someone who knows what they are doing and its not too imo, don't let it keep u from enjoying new wheels
there is a sacrifice but it gets better
Old Oct 7, 2009 | 10:35 PM
  #327
HXS's Avatar
HXS
thanks for encouraging words.
one more question:
so even with my somewhat mild drop (GF210), i'm still gonna rub?
Old Oct 8, 2009 | 11:49 AM
  #328
YellowTail's Avatar
bump on the reference photos...
ps, ive got 19" oems and still havent decided if i wanted to go 20mm/25mm or 30mm/33mm offset.
ive only seen photos of 20mm/25mm references..
Old Oct 8, 2009 | 03:59 PM
  #329
Skaterbasist's Avatar
Retired SuperMod
Originally Posted by HXS
eurodre and shane:
rear fenders rolled
will i rub?
thanks!
FYI: My rears are 10.5 +8 with 275 and camber anywhere in the range of 2-3, and its right at the fender. +0 with that camber setting with definitely rub. You'll need a slight pull on the rears, and a flat roll on the fronts
Old Oct 8, 2009 | 04:03 PM
  #330
Dranom's Avatar
eurodre and shane:
rear fenders rolled
will i rub?
thanks!
yeah this will rub for sure. i had 285/30 w/ -3 camber before and it still rub w/ +9 offsets
what tire you runnin?
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
