Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
  #3436
Old 05-13-2012, 12:17 AM
DrewDrew's Avatar
Lol. It's all up to you - how much camber do you want to run? or rather since you aren't getting front camber arms, how much are you dropping from stock height? from there I can closely estimate how much natural camber you'll have, and give you widths/offsets from there.
I forgot one of your questions was why I went with +4/+6. +4 up front because it's the lowest offset I could do and stay within oem camber. right now, I'm at +2 at -1.4. I wouldn't have minded doing the same with my new wheels, but I had no choice. I'll be running just -1* in the front with the new wheels. 10.5 +6 in the rear because it will require nearly the exact same amount of camber which I like. I hate big differences in camber front to rear, looks off. I'm at 10.5 +3 right now at -1.5*. the new offsets will be -1* just like the front. that's why I went with those offsets.
ambiguous, who I just helped with his offsets, went with +2, +0, IIRC. those offsets will have him run the max amount of suggested camber via the manual/infiniti (-1.4 and -1.8).
keep in mind, you can manipulate the amount of camber you run to get within a certain amount. like, I could've gone 9.5/10.5 et -5 all around (or just whatever the next lip size offsets were, this is just an example), and do a 7-8mm pull front, 5mm pull rear and still be within oem specs. I just didn't want to do any fender pulling - that's just me.
  #3437
Old 05-13-2012, 02:17 AM
TGMcCoy's Avatar
I'm thinking I want to be like you, natural camber, but I want lips... So, there's an issue there. I'll get camber arms for the back, but no camber arms up front is my only thing(at least not at the moment). I want to lower the car to the top of the tire tread on 20" 35 stretched --- havnt measured how much of a drop that will be. Happen to know? How much natural camber will that equal)). I would like as close to 3.5"front/5" lips rear with r disk front for the brembos... Looking at the gnosis hs201's reverse no step lip
  #3438
Old 05-13-2012, 10:01 AM
yungsurr's Avatar
anyone selling g37 wheels the 19 in,
  #3439
Old 05-13-2012, 03:27 PM
DrewDrew's Avatar
Well, I'm not running natural camber. I'm dropped to 23.75" fender heights on 19s, and have SPC and SPL camber kits. I don't know the stock fender heights on 19s. So I don't know how much I'm dropped, nor how much you'd want to drop for 20s.
  #3440
Old 05-13-2012, 08:19 PM
TGMcCoy's Avatar
[QUOTE=DrewDrew;6448794
.[/QUOTE]
What widths and size wheels? 20 or 19 & 9.5/10.5 or 10/11? Is he pulling his fenders at all or are those offsets good for just a flat roll?
Thanks again, Drew, really helping me out!
  #3441
Old 05-13-2012, 10:42 PM
DrewDrew's Avatar
IIRC, he got 19s. Just a flat roll. If I ever talk about offsets and camber that so have a pull, I'll mention it.
  #3442
Old 05-15-2012, 12:35 AM
HXS's Avatar
HXS
HXS is offline
mostly a tire question...
which set-up gives better rim protection:
245/30/20 on a 9.5
OR
255/30/20 on a 10.0?
  #3443
Old 05-15-2012, 01:27 AM
DrewDrew's Avatar
245 on a 9.5, but only by 2mm worth. the rim lip is still exposed tho on those widths. if you want actual protection, you need a 255 on a 9.5.
HXS (05-15-2012)
  #3444
Old 05-15-2012, 01:38 AM
4DGS's Avatar
245/30/20 on a 9.5
OR
Size doesn't matter too much in this case, tire design does. Running tires like Michelin PS2 which have a huge lip protectors will warrant more protection than say Hankooks which have a pretty slim lip protector.
The following 2 users liked this post by 4DGS:
DrewDrew (05-15-2012), HXS (05-15-2012)
  #3445
Old 05-15-2012, 02:09 AM
HXS's Avatar
HXS
HXS is offline
Thanks guys but I wasn't talking about the rim getting rash.
I was talking about the rim getting bent. I guess I shoulda been more clear
  #3446
Old 05-15-2012, 02:14 AM
4DGS's Avatar
I actually thought you may have been getting at that after I hit post lol
In that case, they are pretty much identical. The 255 will be a hair larger but really not much.
Best way to go about that is dropping the tread width a little and upping the profile. For example instead of 255/30 run 235/35 or 245/35.
But if you're just trying to avoid bends and cracks just make sure your tire pressure is always on point.
  #3447
Old 05-15-2012, 02:18 AM
DrewDrew's Avatar
Well, you can have some thick *** tires, but can still bend rims. Am I still not getting your point?
http://i21.photobucket.com/albums/b276/jablon15/rim.jpg
If the guys in Los Angeles can run 225/35s on 10s, and never bend their Works(Im guessing what you have via sig)/Volks/any other forged wheel form daily driving, I wouldn't worry about what I run - especially something with 20mm more. Just drive smart, and keep track of your tire pressure*.
  #3448
Old 05-15-2012, 11:59 AM
HXS's Avatar
HXS
HXS is offline
well i really wanna change to 30 series.
i currently have 225/35/20 on my 9.5 and i really don't like how it stretches anymore.
so i was thinking a 245/30/20 will not be AS stretched.
yes, you're getting my point
you're right... i never really thought about how rims can bend even with thick tires.
thanks again guys, i'll make sure my pressure is on point with whatever i decide to go with.
  #3449
Old 05-15-2012, 11:12 PM
luisp88's Avatar
front 20x9+20
225/35/20
rear 20x10.5+25
245/35/20
would these wheel/tires fit better on a coupe or sedan?
TIA
-luis
  #3450
Old 05-15-2012, 11:46 PM
DrewDrew's Avatar
an aggressive sedan.
you'd need 20mm spacers all around for a coupe.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
Quick Reply: Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
