Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Jul 18, 2012 | 11:35 PM
  #3901
SAMzG35's Avatar
G35
I'm also running 245 & 275 stock height for now. However mine are /30 and on 10 & 11" wide rims
Old Jul 18, 2012 | 11:37 PM
  #3902
Drew113's Avatar
Ban Hammer Expert
^^if your at stock height i do not understand why you went with that setup....
Old Jul 19, 2012 | 03:03 AM
  #3903
d.v35's Avatar
okay so im a bit confused.. my car is at stock height too so shouldn't I go 255/35 front and 275/35 back as the 245/35 front is better for when the car is lowered?
and talking about tyres, can I get any tyres that 255/35 and 275/35 because Im not quite sure about the whole ZR and what those letters mean..
Old Jul 19, 2012 | 01:29 PM
  #3904
MPG35fiend's Avatar
Used legit te37s for 2800? Black.
Or
Brand new varrstoens te37s for $950? Black.
Old Jul 19, 2012 | 01:31 PM
  #3905
Drew113's Avatar
Ban Hammer Expert
IF you have the money i'd get the real thing but if don't care that much about replicas vs authentics you can never go wrong with the varrstoens....had them for over two years and they are the more solid model that they make
Old Jul 19, 2012 | 05:36 PM
  #3906
4DGS's Avatar
Originally Posted by d.v35
hi, just a question im not sure with.. got 19 inch 9.5 front 10.5 rear (+12 all round) deciding to get tyre sizes 255/35 at the front and 275/35 at the rear as I was advised it was the best fit. wouldnt the rear be higher then the front? sorry I just dont know much about the staggered set-up.
Yea that set up is fine. It will be slightly larger tire in the rear but it won't make a difference and to the eye you won't be able to tell.
Ignore what was said 255/35 and 275/35 are fine sizes. Some just opt for a 245/35 because 245s use to be more common. Which isn't really the case anymore. 255s are made by pretty much every tire manufacture now.
Pretty much any tire that comes in that size is fine. The Z is the speed rating for the tire (which I believe is 189mph...) the R just means radial.
Or
Old Jul 19, 2012 | 05:57 PM
  #3907
SAMzG35's Avatar
G35
Reading > you
I had a member selling a set of BC locally but he decided to keep them. So now lost between Tanabe Z40 & stance. Not sure which one to get
Old Jul 19, 2012 | 07:09 PM
  #3908
MPG35fiend's Avatar
LMAO Blain, I know dude!!! I'm crazy right now...... Still researching... SMH
Old Jul 19, 2012 | 09:07 PM
  #3909
pghg35sedan's Avatar
So i have posted and asked this before but Im asking again. Im considering buying a set of wheelsfor my 2004 G Sedan 19x10.5 +24 rears.....last time I was told to run a 245 tire and roughly -3 degrees camber....i recently asked on a V35 sedan facebook page and was told with a flat roll id need -4 degrees to fit a 245 rear tire on a 19x10.5 +24 wheel in the rear......I also have an option of doing a slight pull to run a little less - camber.......I just need to know what camber spec is correct..
Old Jul 19, 2012 | 09:29 PM
  #3910
VMRWheels's Avatar
I don't know if it would be entirely possible to even say with 100% accuracy, as there are tons of variables that will affect how wheels/tires fit. Brand/model tire? If you wanted to pull, how far of a pull? etc.
Old Jul 19, 2012 | 09:40 PM
  #3911
The pull would be minimal....guy said he would be able to do it without evenn crackig paint........as for tires I haven't decided yet....I just want to know what will need to be done to fit a 19x10.5 +24 on the rear of an 04 g sedann
Old Jul 20, 2012 | 01:08 PM
  #3912
4DGS's Avatar
Reading > you
Stance!!! Tanabes don't go low.
Don't let me hard work go to waste!
This depends on ride height completely, if you go low (like you should) you'll need probably -4 or so on flat fenders. If you're height enough for the wheels to clear then -3 and a tiny pull will probably work. When I say pull this is like.... accidentally gaining a couple mm from the roll. But it depends on a few variables as VMR said.
Basically... you NEED rear camber arms or you're going to be pulling. So roll flat, adjust camber to clear and then if you want to straighten the camber a little start pulling and adjusting camber accordingly. You might find a happy medium in a small pull and -3.5.
Remember, every degree of camber is 5mm in offset change.
Read above, but nobody can GUARANTEE the paint won't crack. If he's giving you a guarantee he's either lying or dumb. There are many variables when it comes to pulling fenders. For all you know you could have had your 1/4s replaced by some hack that filled the **** out them. Never know.
Old Jul 20, 2012 | 01:48 PM
  #3913
SAMzG35's Avatar
G35
How low do the Z40 go any idea? Not looking to slam just a nice drop to remove some of the gap. almost 300 bucks in price difference
Old Jul 20, 2012 | 02:32 PM
  #3914
Thanks for some solid info....I have the rear camber arms already..I installed them when I did my coils. As far as the guarantee those werent his exact words.....but I have watched him do a few pulls with no cracking....he seems to be pretty confident that he can do this with mine if they crack oh well not a big problem.
Another positive is that my car was just painted so I know there isnt any filler in the quarters.
Is there a way to run wider that a 245 tire in the rear. People are saying that they run 265 or 275 on this offset and width wheel....only way I can think of is a ton of camber
Old Jul 20, 2012 | 02:38 PM
  #3915
PAIXAO's Avatar
What modifications will be necessary to run the following setup on a 2004 Sedan and what tire sizes would be best??
19x8.5 +18 Front
19x9.5 +22 Rear
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
