Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Tire size question stretch:
19x9.5 and 19x11 - would like to use a 225/40 for the front. What would a good rear size be? 245/40?
and if inner barrels were switched to make 19x10 and 19x10.5... would this be stupid? lol
Just an fyi...@26" fender height my 19x9.5 +40's did not clear the knuckle, ended up with a 15mm spacer and now it is money. your setup is within 1mm of mine so be careful about the clearance you have up front...will post pix of the rubbing on the knuckle later.
I may be incorrect, but would you have to run 245/35 & 265/35 or maybe 235/35 & 255/35 for a better stretch plus they are a little smaller and maybe a more sure thing. ? Anyone else chime in though? I may be incorrect.
Fender rolling
I've got a 2003 g35 coupe lowered on tein basic damper coilovers and have bought 19" varrstoen es 1.1.2 wheels , 19/9.5 +22 on the front with 245/35/19 tires and on the rear 19/11.0+ 25 wrapped with 275/30/19 should I be rolling my fenders it is lowered almost an inch. I also have brembos. Thanks
However common sense is if you rub then roll. If roll is not enough then you pull.
I have a question...Ill be going with BC coils and i want to run SSR sp1's like Marcus runs but not as aggressive..
can someone recommend a semi aggressive offset for this wheel in ? He runs a 19x9.5+4 up front and 19x10.5 +18 in rear. ill be rolling fenders as well.
Thanks in advance for your input.
It will rub less. I believe 225/35 is the size you want for 19s
You want to try to stay within oe specs
For the 18s if your dropped and rubbing roll your fenders
I have an 03 g35 sedan at stock height
I am most looking to buy 20x8.5 +35 rims (so i can rotate tires)
Q1: What is the meatiest tire i can put on in the front and rear to fill up the gap? 245/35 seems like it might be too thin. I ride with a full car a lot and have people in the back seat so I don't want it to rub at all.
Also, would it throw off my speedometer?
Thanks for the help
Thanks for the help
