Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
If I go 19x9.5 front and 19x10.5 rear would it be fine if I go 235/35 and back 245/35 ?
will these rims fit ?
I own a 2003 g35 coupe with brembo package. Ive looked all over arizona for varrstoen es1 wheels even online everyone is backordered. So I'm looking at these str 601.
The sizes are
20x9 + 15
20x10.5 + 20
Some people are telling me they do others that they wont clear the brembos any of your guys is help will be appreciated.
The sizes are
20x9 + 15
20x10.5 + 20
Fitment help! Work Vs-XX 20's 04 Coupe
I've seen some previous thread that were similar but I figured I'd throw this out there in case anything has changed.
I have a 2004 g35 coupe with the brembo brakes, I am looking to buy 20s of the VS-XX.
Here is what was recommended to me:
Front: 20x9 +23 (R DISK) 59 mm lip.
Rear: 20x10.5 +25 (O DISK) 90 mm lip.
F: 245/30/20
R: 285/30/20
It is my daily driver, I would ideally like for things to be flush, or best fitment as possible. I am planning on lowering the car maybe an inch or two in order to get rid of the excess wheel gap created by putting these rims on.
The rep said that this setup would fit without rolling fenders, but I dont care if I need to do that.
Do you think this will work?
Thanks,
Daenis
F: 245/30/20
R: 285/30/20
Thanks,
Daenis
Hi, I have g35 sedan 08 journey. I'm wondering what offset to get on my wheels I'm ordering some forgestar f14 front 9.5 rear 11. i want an aggressive look but not a whole lot camber my car is lowered 2" fenders are rolled. Hope some gurus can help me out. Thanks
I just lowered my car on coilovers, the rear wheels are rubbing on the coilover from the inside rim(when hitting a bump in the road). Only solution is to get spacers, but I have never dealt with spacers. There is already a small amount of camber, if I use 5mm spacers does that push the wheel out 5mm, and add camber, or delete the camber or will it be about the same?
its on a 03 sedan, fenders are rolled, tucking tire on 19x10 wheels in the back
Thanks
Thanks
04 g35 18x9.5 20 et need tire size
Hello guys Just bought a 04 g35 coupe 3 months ago. Bought some wheels for it last week Rota torques 18x9.5 20 et, the car is stock won't lower the car to soon I Need HELP with the Tire size, I do not want problems with rubbing or vdc issues. I've Read of a lot people using 245/40 in the front and 275/40 in the rear would that work for my wheels??
Hey guys,
Planning to get Varrstoen ES1, but contemplating since they only come in 11. Initially based on reading all posts and searching it seems 10.5 +22 with 27/35/R19 would have worked fine.
I am sure there is someone with ES1's 19x11 +15 for the rear, my dilemma is whether they will clear and fit well.
I have a stock 07 G35 coupe 6mt and plan to run them at same for time being (till i can spare cash for coilovers). Also, same tire size 275/35/R19 or should i go 265?
I would just get 245/40 all round and you should be set
Hey guys,
If you're just talking about the rears, 19x11 +15 is a good size to play with. I had the ES2 before same specs and I am lowered on coils. Had to put a 12mm spacer though to make it sit flush.
275/35 if you dont want that much stretch
Thanks
Thanks
Offset of the rim?
F: 245/30/20
R: 285/30/20
Thanks,
Daenis
F: 245/30/20
R: 285/30/20
Thanks,
Daenis
Also, once you lower it you would need spacers to make it sit flush with those specs
First of all, are u planning on getting same size for all 4?
Following is the setup i am thinking of ..
Front: 19x9.5 with 245/35/R19
Not sure of the offset, i am noob. But wonderin if +12 would be nice and flush (initially was planning to get +22).
Rear: 19x11 +15 with 275/35/R19
Would i need to roll my fenders?
All replies appreciated.
Thank you for the reply.
Okay I see, with 245/40 all around would I have issues with Vdc?
