Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Aug 9, 2012 | 03:16 PM
  #4036
4DGS's Avatar
Originally Posted by TGMcCoy
1: They aren't grade 8 steel is why I'm a little worried. They are a2-70 stainless steel from Ace hardware. I was hoping to hear I didn't make a mistake. From some more research, I think I may have.
2: Would this stretch relate to the leaking issue im having on one wheel? Or would it more likely be something else? Would 235/35 front and 275/30 rear look awkward? Or would 265/30 look better?
Thanks for your help guys!
I'm not familiar with that grade system so I can really offer an insight there. Usually stainless is high enough grade that it's close to par with grade 8 but I can't be certain for that. Look up torque specs and what not for that grade and size. If it can handle 40ft/lbs then you're cool.
275/30 would be slightly less stretch than the 255/35 where as the 265/30 is pretty similar. I have 225/35 on 10 and 275/30 on 11.5 and personally I could have gone 265/30 and it would have matched a little better. If you're ok with slightly more stretch up front then 275/30 and 235/35 is perfectly fine.
Old Aug 9, 2012 | 03:29 PM
  #4037
TGMcCoy's Avatar
Thanks, I did order some grade 8 bolts, just to be safe.
Looks like 265/30 are more rare than 275/30. Maybe you can give me advice if I need the 265 or not:
G35 Coupe Rear: 20x11.5 +6.
I just got my rear fenders rolled and I have a camber kit on the back
Old Aug 9, 2012 | 06:45 PM
  #4038
DrewDrew's Avatar
Don't need the 265/30 IMHO. People have run less stretch while being more aggressive. Blain always says "stretch for what you need," but really, either stretch would be fine. If it's easier to get a 275/30, I would stick with that.
Old Aug 9, 2012 | 07:06 PM
  #4039
4DGS's Avatar
Oh 275/30 is fine, I thought you were in the negatives for some reason.
I can't remember but are you going with nankangs? If so I'll take a picture of how my 275/30s stretch on my 11.5s. They're shifted to the outside slightly tho so the stretch looks slightly less. But I'm finding now that something specific to weds wheels.
Old Aug 9, 2012 | 09:37 PM
  #4040
ajthompson94's Avatar
So you want to buy new wheels?
Do you want to stretch tires and poke? Are you lowered? How crazy are you willing to get with the wheels?
Coupe or sedan?
25mm front and 30mm rear. with a roll or 20/25 without.
Any of the 100 online tire retailers.
Just tell him to come on here so you don't have to be relayin' info!
The front will need to be spaced out to match the aggressiveness of the rear..
You're gonna be into an aggressive pull and about -6 or -7 (depending on the pull) To do it without the pull you're into some oni camber specs.
The front as I said, it's really up to how aggressive he wants to go to match the rear. I'd recommend a 15-20mm spacer at least.
4dgs its not lowered but wanting to lower about 1.5" im not into the stretch tire look but willing to go crazy with the wheels and i also want to evetually do a mild camber look and its a coupe
Old Aug 10, 2012 | 12:09 AM
  #4041
DrewDrew's Avatar
Most common thing to do with a 1.5" drop is 9.5/10.5 offsets in the positive teens. 245/275/35. It's not low enough to stretch and pull it off.
To give you an idea, Skaterbasist ran the above widths and tires with +7/+8 offsets, to give you an idea of the drop and specs.
https://g35driver.com/forums/members...0&ref=gnr-prev
He ran between -2.5 and 3* of camber for that set up.
Is that what you're looking for?
Old Aug 10, 2012 | 12:29 AM
  #4042
TGMcCoy's Avatar
My fronts will end up being negatives, after a 10mm spacer, 20x10.5 -6. Those will be 235/35. Hope it won't be too much trouble to clear.
I did go with nankangs, I think I now remember you talking about the trouble with mounting 255 now, lol. One of the tires seemed to have closed the gap a little, but it's still a few mm of barrel showing. Maybe I'll have them try to do again, 150psi till they burst! If not I'll get nankangs or Achilles, they're cheaper and higher tread ware.
Old Aug 10, 2012 | 12:41 AM
  #4043
DrewDrew's Avatar
def should not have any trouble with that stretch on nankangs. they stretch too easily and nicely. they didn't bead just at 40psi?
Old Aug 10, 2012 | 12:45 AM
  #4044
jimmyboi860's Avatar
Question for you Blain,
Friend of mine has a G sedan, what would it take or is it even do-able to fit these rims?
front: 19x10 +21 HP
rear: 19x11 +27 MP
Friend has coils, spc rear camber and toe bolt.
Old Aug 10, 2012 | 01:08 AM
  #4045
TGMcCoy's Avatar
No, they put them up to 100psi to get them where they are now will batting them down and with tons of lube.
I may try again since they've been broken in a little
Old Aug 10, 2012 | 10:52 PM
  #4046
4DGS's Avatar
my 255s had to be aired up to 120 before they seated.
front: 19x10 +21 HP
rear: 19x11 +27 MP
Doable. But he's into some stretch and camber.
The front would be ideal with a 225/40 and the rear should have a 255/35. Rear will need roughly -5 degrees of camber and a decent pull. However with the offset being that high he may need to run a spacer to get the wheel away from the strut. I ran 11 +20 with -5 degrees and a good pull. However Chris (JDM cain) was around +23 or +24 IIRC and he was within mms of the strut.
So, it's doable, but it will take a little bit of tinkering with the camber specs to make it sit right.
The front he'll probably want a 10mm spacer.
Leave em in the sun for a little bit before trying to mount them, sometimes it can help the rubber flex a little.
Old Aug 11, 2012 | 12:41 AM
  #4047
Thanks Blain, I'll let him know asap!
I'm thinking in the future that I would like bigger lips on the Work VSXX that I recently bought. How would I do this? As in how those this work?
Can I just buy a 19" Work VSXX 5" replacement lip and put it on my current rims? But what would it turn the specs of the rim into?
19x9.5 +29 i think 3" lip, WOuld like to make this an 4" or 4.5" lip
19x10.5 +28 4.5" or 4" lip, would like to make this 5" lip
I see VRwheels website that they sell replacement 19" Work VSXX lips..
Thanks!
Old Aug 11, 2012 | 03:22 AM
  #4048
Ferrara's Avatar
I am looking to get 8mm spacers on my oem coupe with 18 inch rims. will I have any rubbing issues with this??
Old Aug 11, 2012 | 03:31 AM
  #4049
DrewDrew's Avatar
oem 18s? no, no rubbing problems...not even close.
Old Aug 11, 2012 | 01:43 PM
  #4050
Drew113's Avatar
Ban Hammer Expert
haha thats a really small spacer to use on oem 18's...
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
