Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Nov 22, 2012 | 08:46 PM
  #4576
4DGS's Avatar
My honest opinion. Buy something nicer than varrs, vossen, stance etc. There's a lot of option out there and you don't need to go the cookie cutter route...
Old Nov 22, 2012 | 08:49 PM
  #4577
4DGS's Avatar
Originally Posted by 05coupeDG
I'm thinking of getting the forgedstar f10 w/steplip.
Wanted 19's but they only have 20 left.
20x 9.0 +18
20x10.5 +20
That's the lowest offsets for these wheels.
I am planing to get some bc coilovers, complete camber kit, fender rolling and tire stretch. Don't want to be too gressive since my car is a new your car and the roads are bad out here, so a semi look would work?
Based on what I will get what should I do to make it work? I really need your expertise on this bro!
I really hope to hear from you!
Thanks....
You do not need any stretch for this set up as the specs are not aggressive.
If you were to add 25mm spacers front and rear then you may require some stretch...
However, without spacers I'd run 245/35 and 275/35.
Let me know if you want info on spacers and stretch.
Old Nov 22, 2012 | 09:10 PM
  #4578
ohfive's Avatar
Definitely want info with spacers and stretch.
Thanks
Old Nov 22, 2012 | 09:16 PM
  #4579
4DGS's Avatar
Run 25mm spacers.
225/35 up front and 255/35 in the rear.
Adjust camber in the rear accordingly, positive for more flushness negative for more tuck. The front will be fine as is.
Old Nov 23, 2012 | 05:04 PM
  #4580
MPG35fiend's Avatar
Has any body ran a 19x8.5 19x10.5 staggered on awd??
I'm thinking about trading for te37s... Please help.
Would the tire sizes/stretch look funny for the same rolling diameter?
Will be going on a cruise and boarding soon so I will not be able to check after Sat afternoon.
Thanks in Advanced...
Old Nov 23, 2012 | 08:07 PM
  #4581
4DGS's Avatar
There is nothing to stretch on an 8.5" wheel. So you're not going to match the stretch what so ever.
Old Nov 24, 2012 | 12:55 AM
  #4582
MPG35fiend's Avatar
I know that really suck...
Old Nov 24, 2012 | 10:07 AM
  #4583
4DGS's Avatar
I'd hold out for some 9.5/10.5 TEs. Running an 2" stagger is not a good idea on AWD because it makes tire sizes even more limited than you were before.
Old Nov 24, 2012 | 10:50 AM
  #4584
MPG35fiend's Avatar
Already had that in mind.. thanks blain.
Old Nov 24, 2012 | 11:50 AM
  #4585
HXS's Avatar
HXS
anyone know if 18x10.5 +23 up front will hit any part of the suspension on the inside of a G coupe?
or would i need to put a small spacer to clear?
Old Nov 24, 2012 | 01:02 PM
  #4586
4DGS's Avatar
Nope you should be good, Christian (Tian) ran 10.5 +25 with negative 2 degrees and was all good!
Old Nov 25, 2012 | 03:24 PM
  #4587
releasedtruth's Avatar
Did not see on search, but I want to confirm that the Coupe 18" 7-spokes are identical all around in terms of weight/fitment. May be able to buy a rear to replace a front (my front wheel tabs are broken off already) Thanks
Old Nov 26, 2012 | 07:53 PM
  #4588
Plur's Avatar
How would this look on a G coupe? 19x9.5 0 and 19x11.5 + 7
Old Nov 26, 2012 | 08:01 PM
  #4589
Drew113's Avatar
Ban Hammer Expert
decent i guess...reason you wanna have such a jump between the front and rear wheel widths??
Old Nov 26, 2012 | 08:03 PM
  #4590
Plur's Avatar
It's my friends vsxx. He's letting me have it for cheap. How does $1800 sound?
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
