Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Dec 12, 2012 | 12:21 PM
  #4711
4DGS's Avatar
For a company like VR that sells the quantity of wheels they sell they should be paying better attention. It's a huge liability building these wheels so if they were to come a part because someone forgot to torque them right then it's on them.
But there is no way a bolt torqued to 30ft/lbs (that should have loctite on it due to who they are) can come loose from any kind of driving activity.
Old Dec 12, 2012 | 02:59 PM
  #4712
VMRWheels's Avatar
Agreed. VR, Wheelflip, MemoryFab, etc. all have to be really careful about that kind of stuff.
Old Dec 12, 2012 | 03:35 PM
  #4713
OBsessed's Avatar
That's a fair point, I hadn't considered the liability aspect. Thankfully that never became an issue. Honestly it's my bad for not keeping an eye on it. In hindsight the first thing I should have done when they were delivered was ask that question and check everything right then and there before I put tires on and started driving on them.
Good lesson to be learned here: Check your nuts when you get new wheels
Old Dec 12, 2012 | 05:04 PM
  #4714
4DGS's Avatar
Yea I agree, but keep in mind some of the general consumers aren't as mechanically inclined to correct or even catch an issue like that.
Old Dec 12, 2012 | 06:13 PM
  #4715
Punishr's Avatar
Would these wheels fit a '05 g35 coupe.
Bolt Pattern 5x114.3
Wheel Hub: 73.1
19x9.5 - Front offset: +22
19x11 - Rear offset: +25
and if they fit what about tires?
Thanks in advance
Old Dec 12, 2012 | 06:19 PM
  #4716
DrewDrew's Avatar
they'll fit, but you would need to get a 66.1 hub ring. otherwise you'll have issues with that larger bore.
tires, 245/275/35.
Old Dec 12, 2012 | 07:08 PM
  #4717
4DGS's Avatar
I'd go 255/35 and 285/35 personally.
Old Dec 12, 2012 | 11:08 PM
  #4718
krazzyborri's Avatar
Can't seem to find a straight answer....
Do OEM 17" 6 spoke Infiniti rims fit a 2006 6MT Coupe with 19" rays???
Old Dec 12, 2012 | 11:18 PM
  #4719
4DGS's Avatar
Yes, as long as the car isn't equipped with any kind of big brake set up.
Old Dec 12, 2012 | 11:27 PM
  #4720
sweet thanks!!
Old Dec 13, 2012 | 10:39 AM
  #4721
Punishr's Avatar
Would they be sticking out too far? also is that offset good? im sure i'd have to roll the fenders
BTW: sorry for all the noob questions
Old Dec 13, 2012 | 11:52 AM
  #4722
Drew113's Avatar
Ban Hammer Expert
Fenders will need to be rolled with those offsets AND tire specs but its a good offset to be able to still use meaty tires
Old Dec 13, 2012 | 12:50 PM
  #4723
VMRWheels's Avatar
Wheel Hub: 73.1
Thanks in advance
19x9.5 +22/19x11 +25 will fit without an issue, just get 73.1 to 66.1 hubcentric rings. 245/35/19 and 275/35/19 tires are what I'd recommend as well, but you can run wider tires if you roll your fenders.
Old Dec 13, 2012 | 09:21 PM
  #4724
ASTran's Avatar
I am planning to put a set of Work Gnosis HS 203 Matte Black on a 2006 G35 Coupe. I would like to run in the front 19 x 9.5 R Disk and rear 19 x 10.5 O Disk but am not sure of the offsets. I do not want the rims to poke out but even with the front and rear fenders. I do not mind the mild aggressive offsets if there is such a thing but not too aggressive . My fenders are rolled flat. Any recommendations are grateful.
Old Dec 13, 2012 | 09:57 PM
  #4725
Drew113's Avatar
Ban Hammer Expert
with those wheel widths you should stay in the low teens offsets to get the flushness you are looking for....throw some 245/35 and 275/35 tires on and your good
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
