Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Jun 10, 2013 | 12:09 PM
  #5776
CYokG's Avatar
Originally Posted by Crack3r
Ok I have a set of 19x8.5 and 19x9.5. I already have a pair of 255/40/19 on the rear two, and am considering putting on 225/35/19 on the front two. Can I put a smaller diameter on the fronts? I don't want a fat tire or a really stretched look...what is a good size to match the rear?
Well manufacturer puts 245 on an 8.5" width . but i think it has a little bit too much meat for me . I like 235 on an 8.5" wheel. perfect fitment . real flush with the wheel IMO . 225 on an 8.5" has a minor stretch
Old Jun 10, 2013 | 09:01 PM
  #5777
Crack3r's Avatar
Could I put a 35 series tire on the front even though I have 40 in the rear? I'm concerned that may lower the front end more than I expected, even though I will drop it a little bit
Old Jun 11, 2013 | 01:40 AM
  #5778
iamchris's Avatar
Quick question, just rebuilt a set of rims how I can find out if everything is sealed properly without mounting the tire.
Old Jun 11, 2013 | 05:35 PM
  #5779
JKL1031's Avatar
Originally Posted by Geewhiz420
Hey guys, about to purchase some new wheels for my g
I was looking at some wheels with these specs.
Size: 18 "x 8"
Bolt Pattern: 5x100 & 114.3
Off Set: +40mm
I was wondering what size offsets for front and back, should i do 25 front 30 back?
Bump
Also not sure about tire size to much. I'd appreciate any help!
I know theyre nothing fancy. but much better then stock 17's i have. :]
I even know those will fit weak.
Old Jun 11, 2013 | 05:40 PM
  #5780
TGMcCoy's Avatar
I'm pretty sure those are Honda fitment
Old Jun 11, 2013 | 07:43 PM
  #5781
Crack3r's Avatar
Can I put a 35 series tire on the front two wheels while having a 40 in the back?
Old Jun 11, 2013 | 08:31 PM
  #5782
bchalks's Avatar
I have 350z H-techs and 245/35/20 +32 up front and 285/30/20 +30 rear
What size spacers should I go with? I was thinking 15mm front 5mm rear. Can I go 5mm more aggressive than that with OEM camber specs and 350z H-techs and still not rub? 20mm and 10mm? I already rolled my rear fenders.
Old Jun 12, 2013 | 12:27 AM
  #5783
TGMcCoy's Avatar
You can so whatever you want-
Old Jun 12, 2013 | 12:39 AM
  #5784
ItsA..Gthing's Avatar
Dont do that...will give you abs problems,slip,and vdc issues..
Keep same height of tires...Wheel sensors will read different heights at diffetent speeds..
Old Jun 12, 2013 | 04:44 PM
  #5785
obsidian_g35's Avatar
Hello all,
So I have a question about buying new wheels.
I'm planning to get Varrstoen ES 2.2.2s for my 05 Coupe and was wondering what's a better offset which leans more towards performance, +12 or +22
Note: I will be dropping the G with BC coils, probably finger gap in the front and finger and a half in the rear.
19x9.5 front +12 or +22 [245/35 hankook Ventus v12]
19x10.5 rear +12 or +22 [275/35 hankook Ventus v12]
Please advice, and thank in advance.
Old Jun 12, 2013 | 08:59 PM
  #5786
g35owner5's Avatar
Obsidian_g35 - I believe +22 is better for performance. The more positive offset, the better the grip of tires and the lower the center of gravity so handling will be better as well.
Old Jun 12, 2013 | 09:02 PM
  #5787
g35owner5's Avatar
Hey guys,
Does anyone know if the ipl rims will fit on an '05 g35 coupe without modification? I did as much research as possible and the OEM sport rims (Rays) I have on are 19x8 +30mm offset front and 19x8.5 rear +33mm offset. The IPL rims are 19x8.5 +43mm offset front and 19x9 +45mm offset rear.
My only concern is the front set of rims. I've ran 20" rims that are 20x8.5 +35mm front and 20x10 +40mm rear (10"+1.57"=11.57"). With the 20" rims on the back I know the width is larger than 19x9 +45mm (9"+1.77=10.77"). But the front is a different case 20x8.5 +35mm front (8.5"+1.38"=9.88") and 19x8.5 +43mm front (8.5"+1.69"=10.19"). So the IPL rims are still roughly .30" extended towards the fender. My front fenders are also rolled so I have a little more lee-way but I'm not sure how much. Any advice is appreciated. Thanks.
Old Jun 12, 2013 | 10:08 PM
  #5788
Thanks a lot man, ya I was also leaning towards the +22. +12 seems to be more for show and flush looks.
Old Jun 13, 2013 | 04:12 AM
  #5789
Also, would I need fender rolling? Or camber kit?
Originally Posted by obsidian_g35
Hello all,
Old Jun 13, 2013 | 03:06 PM
  #5790
g35owner5's Avatar
You would need a camber kit if you plan on lowering your car as it would alter the alignment.
And from the width of the wheels plus the +22 offset......seems like you're trying to find out the same answer as me. With that setup you're going for, you would definitely need to roll the fenders. The wheels might extend past the fender, but if you're looking for the "wide wheel" look then you're fine. I'm trying to stay inside the fender because I live in the Northeast and there's too many potholes which could cause a lot of problems.
19x9.5 +22 (9.5"+0.87"=10.37") Your stance is wider than mine so depending on what you're going for you may or may not have a problem.
19x10.5 +22 (10.5"+0.87"=11.37") You'll still be inside the fender. No need to roll the rear fenders.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
