Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Jun 13, 2013 | 10:05 PM
  #5791
pat2481's Avatar
if i drop my car 1.6-2 inches how will my tire wear be effected?
Old Jun 15, 2013 | 01:14 PM
  #5792
Clim95's Avatar
Exclamation Tires
I currently have a pearl white 07 g35 coupe with 19s, im looking to buy CV3s that are going to be 20 inches, and i still want to lower it by an inch or inch an a half, what should my tire sizes be?
thanks!
Old Jun 15, 2013 | 01:36 PM
  #5793
gary c's Avatar
The answer depends on the offset/width of your wheels! Without that information we'd be guessing what might work. Post what you intend to buy and you'll get an answer....Gary
Old Jun 18, 2013 | 12:29 AM
  #5794
mkstock33's Avatar
New to the Forum
So I have a 2006 Infiniti G35x and I'm looking to get some VMR V710's.
http://www.carguynation.com/index.ph...FWJlMgodkAUA3Q
What is the best setup to get without having to get new tires?
Old Jun 18, 2013 | 07:27 PM
  #5795
bdubct's Avatar
HELP! what offsets should i run!
im running xxr 521 20x10.5 +30 and 25mm spacer= +5 all around...
im buying varrstoen es1 18x10.5 ... should i run +30, +25, or less (with my 25mm spacer) to run a positive, negative, or zero offset?
what do you recommend and why?
Old Jun 18, 2013 | 07:39 PM
  #5796
thegreatkwijibo's Avatar
well it depends on what you want. I personally am not at all a fan of the hellaflush thing so I would go +30 without the spacer. But I'm guessing you like it or you would never have bought a 25mm spacer. in that case go lower and you can be more aggressive, or if you're happy with your fitment, and just want a different wheel design get em at +30mm and throw your spacer on there.
Old Jun 18, 2013 | 07:52 PM
  #5797
Xet's Avatar
Xet
Umm if you are buying new wheels, buy the right offset from the start, don't plan on using spacers when you have the option not to.
As far as specs it depends on what kind of look you are going for and how aggressive you want it to be. You're probably searching for something around +12, 0, or -X depending on what you're looking for.
Old Jun 19, 2013 | 10:40 AM
  #5798
HenryLee's Avatar
The heck? Why am I the first post? I didnt even make/start this thread.
Old Jun 19, 2013 | 10:57 AM
  #5799
bdubct's Avatar
HELP WITH OFFSETS! Varrstoen ES 1... easy question..
Im currently running xxr 521 20x10.5 +30 and 25mm spacer = +5 et all around. 245/35/20 tires. Im looking to buy a set of varrstoen es1's 18x10.5 and run no spacers but still have a little poke and that agressive look (unless you think otherwise...?) let me know what offset i should get. i have a 2003 g35 coupe black 6mt w/ bbk (brembo brakes). i need at a +12 offset or less to clear the front brakes. i would like to not run staggered, i want 10.5 all around (i would do 19x11 but theyre all out). i still plan on running 245/35 tires so i mild stretch.
so my question is what do you recommend for a good look? i want to slam it like it is now.
18x10.5 +0 no spacers
18x10.5 +12 no spacers
18x10.5. +22 with my 25mm spacer = -3 et
Old Jun 19, 2013 | 11:06 AM
  #5800
ItsA..Gthing's Avatar
First of all your wheels and fitment look good..imo 18's look way to small...If you decide to go with ES1 stick with 20's...
Old Jun 19, 2013 | 11:43 AM
  #5801
bdubct's Avatar
yeah.. but the front lip is so high off the ground and im pretty low... i need to go down on wheel size
Old Jun 19, 2013 | 11:54 AM
  #5802
iamchris's Avatar
Quick question, just rebuilt a set of rims how I can find out if everything is sealed properly without mounting the tire.
Old Jun 19, 2013 | 11:58 AM
  #5803
TORETTO's Avatar
go around the space between the two barrels with silicone. if you put it on smoothly, it shouldn't leak. or play it safe and just put a crap load of silicone on it. only other way I could see without mounting a tire is to spray soapy water around the bolts and take an air compressor around the silicone to see if any parts bubble.
I don't know. I'd just go with the super heavy 50000 layers of silicone and call it a day.
Old Jun 20, 2013 | 11:08 AM
  #5804
steven4931's Avatar
18" Varrstoen es2 coupe offset
I'm getting the varrstoens es2 in 18x9.5 in the front and 18x10.5 in the rear, can anyone tell me what kinds of offset i could run.i want it to be flushed with the fender and i will have a bit of stretch on my tires. My coupe is also lowered.
Old Jun 23, 2013 | 11:38 AM
  #5805
ZachG35's Avatar
I have a 2007 G35 with 225/40/19 in the front and 245/40/19 in the rear. I was wondering if I went 245/40/19 all around if that would screw up my handling at all?
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
