Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Jul 22, 2013 | 08:02 PM
  #5896
pch2005's Avatar
Okay so my specs are as followed -
Driver side =
-2.4 camber
8.7 caster
.03 toe
6.2 SAI
3.7 included angle
Passenger side=
-2.9 camber
8.7 caster
.06 toe
7.1 SAI
4.1 included angle
Rear camber
Driver side
-3.4
Passenger
-3.8
Old Jul 22, 2013 | 11:46 PM
  #5897
JKL1031's Avatar
Y r u trying so hard to fit into some terrible fad?? Why??
Old Jul 23, 2013 | 12:08 AM
  #5898
pch2005's Avatar
Hahaha! Right.....excuse me for not following the cooki cutter trend. I bought the wheels I want and now I have to build/modify around them. If that means trying different tire setups to make them fit better then my all means i will do so. If my fenders get wavy or if the bumpers need to be shaved a couple of hundred thousands of an inch then so be it..no big deal. Car will be painted and any imperfection will be fixed...that's more than a lot of guys on here having tored up fenders. Gotta push the limits. My alignment settings aren't exaggerated like most and that's what I want to avoid.
Old Jul 23, 2013 | 12:50 AM
  #5899
TGMcCoy's Avatar
What are the wheel specs again? Looks you have to kick in some negative camber some
Old Jul 23, 2013 | 01:12 AM
  #5900
pch2005's Avatar
20x10.5 -16 225/35/20 - I need to pinch, pull a little more, possibly add half a degree negative camber from where I'm at now for the fronts. Bend bumper tab or with an angle grinder remove some material and shave bumper a tad bit.
Rears are 20x11.5 -23. Currently have a 255/35 but swapping them for a 255/30 this week. Maybe pull a little more and that's it. Maybe add half a degree or less of negative camber to match the fronts but I doubt it. Coils are maxed and I'm running 16k fronts and 14k rears.
Old Jul 23, 2013 | 04:13 AM
  #5901
TGMcCoy's Avatar
I'm not even close to those specs and running 5* negative camber. Your fenders all pulled excessively?
Old Jul 23, 2013 | 07:40 AM
  #5902
pch2005's Avatar
With the wheel jacked up
Once I put the 255/30 it will clear
Old Jul 23, 2013 | 10:51 AM
  #5903
TGMcCoy's Avatar
Oh damn, Yea, those are pulled all right.... Are you trying to clear just the tire or the lip too?
Old Jul 23, 2013 | 11:45 AM
  #5904
pch2005's Avatar
Yeah, I haven't decided yet on what I want to accomplish - whether to clear lip or just tire. I have an Eastwood fender roller and a heatgun, it only took 8-10 mins to pull that fender on my first try. When I did my brothers 350z I had to keep un-mounting and re-mounting his rims. This time I already knew how much I needed to pull. From there I removed the strut and jacked the wheel as high as I could to see the end result and how much clearance I had.
Old Jul 23, 2013 | 12:19 PM
  #5905
pch2005's Avatar
What A arms would you recommend? SPC? kinetics?
Old Jul 23, 2013 | 12:26 PM
  #5906
JKL1031's Avatar
I recommend you find some narrower wheels. lol
Old Jul 23, 2013 | 12:35 PM
  #5907
pch2005's Avatar
You do understand it's the Big Boy offsets I decided to play with not the width of the rim I choose. There are guys with cookie cutter wheels that also run a-arms as well...newb lol
Old Jul 23, 2013 | 12:39 PM
  #5908
JKL1031's Avatar
Gotcha. But ur the one who looks stumped. Once u figure it out u'll be able to say here's to all the haters who doubted me.
Old Jul 23, 2013 | 12:54 PM
  #5909
pch2005's Avatar
Looks can be deceiving...I know what I need but trying to find alternate ways of getting there but your right.
Old Jul 23, 2013 | 05:35 PM
  #5910
TGMcCoy's Avatar
I have spc a arms, but any should work. You arnt planning ok much negative camber anyways.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
