Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Mar 11, 2010 | 12:20 AM
  #691
TwilightSedan's Avatar
How come everyone on here calls the g35 coupe 19's rays but don't call the g37 Sport 19's Enkei's? I had to find that out myself.
Old Mar 11, 2010 | 10:53 AM
  #692
hamzafraj's Avatar
I am purchasing AXIS MATRIX 20x9 5x114 +22 offset FRONT with 255-35 falkens; 20x10.5 5x114 35 offset REAR with 285-30 falkens; For an 06cpe.
Wondering how would this set looks and more importantly if it will ever rub?
Old Mar 11, 2010 | 05:14 PM
  #693
4DGS's Avatar
^far from rubbing, you should have picked a much lower offset in the rear.
You won't rub.
Are you lowered?
Old Mar 11, 2010 | 05:27 PM
  #694
hamzafraj's Avatar
not lowered. I would love to lower it, but only to a point where there will be no rubbing what so ever.
How low should i go?
Old Mar 11, 2010 | 05:48 PM
  #695
4DGS's Avatar
As low as you think you can go!
With that +35 in the rear I don't think you'll be rubbing at any drop. And even then, just roll your fenders.
Honestly, roll your fenders anyways, better safe than sorry.
Old Mar 11, 2010 | 05:59 PM
  #696
hamzafraj's Avatar
Spacers??
Old Mar 11, 2010 | 06:05 PM
  #697
deeznutts23's Avatar
does anyone know if a set of volk gts 10.5 +18 will clear oem brembos? the wheels sizes are the same for the front and back. the wheels are c disk.
Old Mar 11, 2010 | 06:33 PM
  #698
4DGS's Avatar
Originally Posted by hamzafraj
Spacers??
Yea sure, probably a 10mm-15mm.
Get your fenders rolled anyways.
Deeznuts, yes those should clear Brembos. A disk is the most ideal for brake clearance I am pretty sure, but with that offset I think you'll be fine.
Old Mar 11, 2010 | 06:45 PM
  #699
hamzafraj's Avatar
Thanks you
Can't wait to see the results
Old Mar 11, 2010 | 07:41 PM
  #700
TastefullyDone's Avatar
The offset doesn't matter on whether it will clear your brakes. Its the disc type that will tell you. With brembo the front definitely won't clear with C disc. A-disc is Volk/Ray's version of high disc to clear bbk. The rears I know the B disc clears oem brembo, but not sure if C does, I would take a guess that it probably does. If not you can always get a sandwich style spacer for the rear to clear.
Old Mar 11, 2010 | 08:26 PM
  #701
4DGS's Avatar
^ I can't remember the exact specifics of the discs.
I THINK it goes.
A; Clears any brakes has little lip. (front and rear)
B; Huge lips, clears very little breaks
C; I can't remember for the life of me....
Old Mar 13, 2010 | 03:38 PM
  #702
nsurg's Avatar
xxr 518 18x8.5--input on rear spacers?
I want to get some xxr 518 wheels, all black, 18x8.5 with 35mm offset for my 2004 g35 (with brembos). Sure I'd like bigger, but this is what I chose to budget for it and my stock-size tires are in good condition still. Staggered would be cool, but not really an option for this wheel unless I go to skinny up front which would prob not fit my oem tires.
I was looking at this: http://cgi.ebay.com/ebaymotors/18-XX...Q5fAccessories
or this: http://cgi.ebay.com/ebaymotors/18-XX...Q5fAccessories
As these are 8.5 in front/rear, I'm told my oem-sized tires will fit and that a 35mm offset will clear my brembo caliper covers. I love the look of these wheels, and they are cheaper than the other stuff I like.
****Biggest question is, should I/could I put a spacer behind the rear wheels to make it a bit of a wider stance, or would this be stupid?
Any comments would be greatly appreciated, I'll probably buy this within the week!
Old Mar 13, 2010 | 07:17 PM
  #703
NFSP G35's Avatar
? = 2B || !2B
^I actually considered those same wheels in a 19 with a TA stripe. In the end I decided to go with something less sporty and more classy. But if you're going for a sporty look, I say go ahead.
The 19's would look better, and aren't much more. Tires will be more costly though.
Old Mar 14, 2010 | 12:27 AM
  #704
nsurg's Avatar
Yeah, red stripe/TA is a bit too much for my preferred look. 19s would be fine but I will ultimately be saving money for a lotus elise down the road--I must get new wheels for my g35 b/c three of my wheels are "etched" and leaking 10lbs/week of air. I'm tired of using my pump, and it would cost almost as much to fix the leaking problem.
So rather than look all badass as a goal, the wheels are practical replacements for stock, and my tires are fine for now.
Any opinion on spacers or not?
Old Mar 14, 2010 | 08:45 PM
  #705
856_reilly's Avatar
hey guys, Waiting on my wheels and need some help with tire sizes. I'm goin to be running 20x10 with 0 offset in the front and a 20x11 rear with a 0 offset. There is goin to be a fender roll and a slight pull done, but need some help on the sizes. Anyone help? thanks......
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
