Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Mar 21, 2010 | 04:40 PM
  #736
4DGS's Avatar
More paper thin brake clearance lol
That is looking like it's actually rubbing, you need spacers. If it didn't look like it was rubbing then you'd be fine. Wheels don't move anywhere.
Old Mar 21, 2010 | 04:42 PM
  #737
coreydee's Avatar
Thats what some people were saying too. As long as it's not rubbing then I'm fine. It's not. But whenever the time comes to replace the pads, the wheels will probably rub then huh?
  #738
4DGS's Avatar
Originally Posted by Marks G
with wheels and tires sizes of 20x9.5 +20 front 245/35/20 and 20x10.5 +25 rear 275/35/20.. whats a decent size spacer to run on the front/back to get a flush set up since there is no poking here..
and my fenders are already rolled i just dont want to rub too much
ANYONE ?
How flush you want?
15mm rear and 10mm front will look better and not rub.
Old Mar 21, 2010 | 04:44 PM
  #739
4DGS's Avatar
I'd buy a 5mm spacer regardless, better safe than sorry. You don't want to scrape your brembos.
Old Mar 21, 2010 | 04:49 PM
  #740
coreydee's Avatar
Is there a brand or vendor you'd recommend? And what's the difference between the v1 or v2? Will I need to remove the studs? Or get longer one's? Sorry I'm a newbie and just don't want to buy the wrong things.
Old Mar 21, 2010 | 05:12 PM
  #741
4DGS's Avatar
Assuming you;re referring to Ichiba's
v1 is held onto stock studs with your lugs, if you're only using a 3or5mm spacer than v1s are fine. anything larger you should use v2. IMO use v2 regardless of anything.
V2 has it's own studs that act as an extended stud. Basically you bolt the spacer on as an extension to the hub assembly then you don't lose any thread space when torquing on your wheels.
All of out vendors on the forum are great, PM around and get the best price.
Sum it up, buy Ichiba v2s.
Old Mar 21, 2010 | 06:15 PM
  #742
coreydee's Avatar
4dgs,
Thanks man, I appreciate all of your help with clearing this up for me.
Old Mar 21, 2010 | 06:22 PM
  #743
coreydee's Avatar
If my wheels are 35 mm offset in the front (coupe), do you think a 15 mm spacer be too much?
Old Mar 21, 2010 | 07:10 PM
  #744
4DGS's Avatar
How wide are the wheels?
Old Mar 21, 2010 | 07:23 PM
  #745
coreydee's Avatar
19x9.5 fronts...
Old Mar 21, 2010 | 08:03 PM
  #746
4DGS's Avatar
You could pull off a 15mm
Old Mar 21, 2010 | 08:21 PM
  #747
coreydee's Avatar
sweet. Thanks bro.
Old Mar 21, 2010 | 11:56 PM
  #748
SkylineGTR2789's Avatar
Originally Posted by 4DGS
^ flush? or hellaflush?
25F 30R.
But slam it.
thanks man
Old Mar 22, 2010 | 12:09 AM
  #749
deeznutts23's Avatar
easily. id put a 20mm to be a little more flush
Old Mar 22, 2010 | 02:14 PM
  #750
coreydee's Avatar
so 20 mm on the front, front is 19x9.5 w/ 35mm offsets
my backs should be fine right?
or would that spacer of 20mm instead of 15mm push it out more than the rear? Rear is 19x10.5 w/ 22 offset
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
