Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Mar 10, 2015 | 04:09 AM
  #7231
SAMzG35's Avatar
G35
Guys any idea if I can run 285/30/20 instead of 275/30/20 on my 20x11 +15?
Old Mar 10, 2015 | 06:13 AM
  #7232
TGMcCoy's Avatar
How does your 275/30 fit? If you have room, do it?
Old Mar 10, 2015 | 03:03 PM
  #7233
BenitesG35's Avatar
I juss bought spc camber and toe I'm trying to save my tires they are 19x10.5 +12
Old Mar 10, 2015 | 03:28 PM
  #7234
ScraggleRock's Avatar
Good question.
Old Mar 10, 2015 | 04:09 PM
  #7235
BenitesG35's Avatar
How much camber should I use ?
Old Mar 11, 2015 | 04:03 PM
  #7236
Conissah's Avatar
Poke?
These wheels are almost exactly the same offset as my other set of wheels. Yet, they poke out a lot more. It's slightly concerning but when I have tires on and its on the ground, they will "sink" some right?
Old wheels
F: 19x9.5 +29 with a 3mm spacer (+26)
R: 19x10.5 +28 with a 5mm spacer (+23)
New wheels
F: 19x9.5 +22
R: 19x11 +25
Im stumped
Old Mar 11, 2015 | 04:47 PM
  #7237
Plur's Avatar
^well your specs arent exactly the same it's gonna be 4mm more poked all around.
Old Mar 11, 2015 | 07:41 PM
  #7238
PhoenixG35's Avatar
19 x 10 +22
19 x 11 +25
I'm hoping for a flush look with minimal camber...if I roll the fenders, think I can succeed?
Old Mar 11, 2015 | 07:42 PM
  #7239
Lartytiejdke3's Avatar
Originally Posted by PhoenixG35
19 x 10 +22 19 x 11 +25 I'm hoping for a flush look with minimal camber...if I roll the fenders, think I can succeed?
should do the trick
Old Mar 11, 2015 | 09:58 PM
  #7240
Conissah's Avatar
This is the fitment of my last set. This isn't a 4mm difference.
Old Mar 12, 2015 | 10:21 AM
  #7241
ryno2_3's Avatar
Hi everyone this is my first post ever, been a lurker for quite some time. I been doing ALOT of research on this but After a 100 plus pages I broke up and decided to ask a few questions about a my so to be tire/rim set up. I have a set of rims on the way Size - Front : 20 x 9.0 / Rear : 20 x 10.0 Offset - Front : +18mm / Rear : +25mm. My car have a Front and Rear Camber kit. It is NOT lowered. Stock height. I do have Brembos. My first question is will these clear my brembos or will I need a spacer? The saleman told me they should clear them but I might need a spacer. If I do need one, will 5mm work? The tires are a 245/35/20 and a 275/30/20 size. My second question is will I rub with this set up? I read on here that i better set up is 255/30/20 and 285/30/20. Would you agree? I wanna keep the camber near to zero for better wear.
Old Mar 12, 2015 | 10:30 AM
  #7242
ryno2_3's Avatar
^^I should probably add that I wanted beefer tire because the roads arent the best where I live. Ugh IOWA. Any suggestions?
Old Mar 12, 2015 | 12:19 PM
  #7243
ronnieballgame's Avatar
You went from 10.5 to 11 in the rears, you need to also factor in the effects of the increased width will push it out an additional ~6.5mm from your previous set up so you are > 10mm difference in the rears.
Old Mar 13, 2015 | 10:56 AM
  #7244
Conissah's Avatar
19 x 10 +22
19 x 11 +25
Look at my post above (#7237). Thats 19x9.5 +22 in the front and 19x11 +25 in the rear. Ill post pics when they have tires on them and on the ground. I dont have my rears rolled btw.
Old Mar 16, 2015 | 06:05 PM
  #7245
TheefrshstVQ's Avatar
Hey guys,
I have some chrome OEM 18's that I want to put on my car. I personally don't like the chrome and want something similar to the stock silver color. I've seen someone sand chrome wheels down to the metal and I thought it looked good in pictures but have a fear that it doesn't in person.
My question is should I plastidip the wheels with the true metallics aluminum color for a cheap fix? or is wet sanding the wheel with a very high gritgoing to get me the color I'm trying to achieve?
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
