Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Feb 20, 2015 | 05:42 AM
  #7216
Time2findDaJuan's Avatar
ok so i have 18x8 and 245/45/18 all around and I really want spacers just don't know which size i should get.
have a stock 06
view of the wheels :l
http://gyazo.com/1e360e355a5b45367382487d6d8e645f
http://gyazo.com/30cc77704d329d2b58101c0ad372e301
Old Feb 20, 2015 | 08:39 AM
  #7217
the93owner's Avatar
Originally Posted by Time2findDaJuan
ok so i have 18x8 and 245/45/18 all around and I really want spacers just don't know which size i should get. have a stock 06 view of the wheels :l http://gyazo.com/1e360e355a5b45367382487d6d8e645f http://gyazo.com/30cc77704d329d2b58101c0ad372e301
Depends what the offset of the wheels are.
Old Feb 20, 2015 | 07:54 PM
  #7218
No offset its just 18x8 all around
Old Feb 20, 2015 | 08:21 PM
  #7219
the93owner's Avatar
Every wheel has an offset, unless you mean no offset as in 0 offset.
Old Feb 20, 2015 | 08:34 PM
  #7220
BowWizzel's Avatar
have a stock 06
You should lower your car before trying to add spacers. What size is on how you want it to look. My taste would be 20-30mm from the looks of that rear but thats me, be prepared to roll fenders or stretch tires then.
Old Feb 20, 2015 | 11:14 PM
  #7221
ookkk found out its +35 offset and I don't plan on lowering
Old Feb 20, 2015 | 11:18 PM
  #7222
Don't wanna lower or roll my fenders I just don't want my wheels to be so hidden and like inside lol
Old Feb 20, 2015 | 11:35 PM
  #7223
David1017's Avatar
I just ordered some Varrstoen es2 19x9.5 +22
19x11 + 25
Should I roll fenders?? Help guys, I'm new to this. Also what tire size is recommended?
Old Feb 20, 2015 | 11:52 PM
  #7224
the93owner's Avatar
15-20mm should be safe, but on stock suspension you generally don't need to worry about fender issues so you can get wider spacers if you want.
Old Feb 20, 2015 | 11:54 PM
  #7225
the93owner's Avatar
Originally Posted by David1017
I just ordered some Varrstoen es2 19x9.5 +22 19x11 + 25 Should I roll fenders?? Help guys, I'm new to this. Also what tire size is recommended?
Depends if you want a stretched look, for a 9.5 I would recommend a 245 or 255 and for an 11 I would go with a 285. You can go smaller for a stretched look or wider for a meatier look. And yes you should roll fenders.
Old Feb 21, 2015 | 12:16 AM
  #7226
David1017's Avatar
Thanks! Do you think I'll need spacers? Im lowered 2' in front and 1.5' in the rear
Old Feb 21, 2015 | 10:21 AM
  #7227
the93owner's Avatar
With those specs I think you should be fine. Do a test fit and see how you like the look. If you want it more aggressive then you can see what size spacers to get.
Old Feb 21, 2015 | 11:15 AM
  #7228
David1017's Avatar
Cool, thanks for the help!
Old Mar 3, 2015 | 04:01 AM
  #7229
TGMcCoy's Avatar
Any idea how high of an offset 19x12.5 would fit the rear of a 03 g35 coupe with true coilovers? Would be from 6-7 degrees negative camber.
Looking to be positive offset probably 19x12.5 +6 or close to
Old Mar 8, 2015 | 02:50 PM
  #7230
kchar92's Avatar
Hey, I'm currently running 20x10.5 +30 & 20x9 +25 on my coupe. I want a more aggressive/flush look.. Not TOO aggressive, just enough so that it'll look nice. What size tires should I run? I know I'll need a little stretch, camber (I already have camber arms front and rear) & spacers, but not sure what size to get & how much camber.. Help anyone? Btw current tires are not stretched & I'm lowered about 2 inches.
Thanks in advance.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
