Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Oct 16, 2015 | 11:40 PM
  #7366
ferniee23's Avatar
Hey guys I have a few questions, I just sold my 5at and picked up a 6mt and want to start building it for the track, im going with 18s but not sure what offsets,width and weather to do staggered or a square set up, planned on getting enkei rs05rr, also I have some camber arms sitting around and will be throwing them on soon but was wondering what i should have them set at,
thanks guys
Old Oct 17, 2015 | 02:28 AM
  #7367
ScraggleRock's Avatar
Originally Posted by nervseele
Thanks for the reply tyke, I can definitely afford an alignment, it's the camber kit that will kill my wallet, so I guess I'll just drop it and get an alignment now and then get a camber kit in the next few months
Haha nothing I find more incredible than someone who can afford a G35 (with its horrible MPG) + Coilovers but can't afford a camber/toe kit...but apparently have limitless amounts of money for tires. Please do us all a favor and sell your car before you ruin it for the next owner.
Old Oct 22, 2015 | 07:05 PM
  #7368
timandytimandy's Avatar
I've been searching for a while now and cant get any solid answers to my concerns. Just bought a 2003 sedan and looking to run these specs. What fender work do I need to make them fit?
Front:
18x9.5 +22
225/40
Rear:
18x9.5 +14
235/40/18 tire.
stock / 0 camber.
Old Oct 22, 2015 | 07:27 PM
  #7369
ciraleon's Avatar
Front:
18x9.5 +22
225/40
Rear:
18x9.5 +14
235/40/18 tire.
stock / 0 camber.
Front will be fine. Rear might need a slight roll depending how low you are. You have coils?
Old Oct 22, 2015 | 07:41 PM
  #7370
Going to have either PBM or ISC in a true coilover style. Trying to stay away from a major pull but still be flush.
Old Oct 24, 2015 | 08:48 AM
  #7371
bryanr's Avatar
Considering switching my wheels from 18s to 19", most likely Work, on my Sedan (rwd)
Want to know the max specs I can run without fender rolling. I have oem 350z suspension now, but will be getting coilovers with dampening adjustment before the wheels.
Want to run 19X9.5 +20 something front, 19X10.5 +32 or +25 rear.
Have considered 10" up front but dont want to run into major fitment issues.
Thanks!
Old Oct 24, 2015 | 10:44 AM
  #7372
ciraleon's Avatar
Are you guys scared of fender rolling? I keep seeing it. "I don't want to have to roll the fenders."
It's such a normal thing to do and it's so EASY!
Old Oct 26, 2015 | 07:24 PM
  #7373
Chucky1's Avatar
2003 G35 sedan
Would a 18x9 +25 rim work on all four corners? If so, what size tire would be good? Car is at the original ride hight. If not, what offset would be best. I get lost trying to figure offset.
Thank you
Old Oct 27, 2015 | 12:33 AM
  #7374
That's what I'm sayin, man. A heat gun and a wooden baseball bat and its cake.
Old Oct 27, 2015 | 02:36 AM
  #7375
BlackG2017's Avatar
I'm on BC racing coilovers and I'm getting really bad wear on the inside of the tires do I need to get front adjustable control arms and a rear camber kit to stop this. If so what would you guys recommend?
Old Oct 27, 2015 | 02:56 AM
  #7376
You need adjustable control arms as well as eccentric toe bolts in the back.
SPC for the toe bolts, SPC, Eibach or SPL for the rear arms, and SPC, Eibach, or Kinetix for the front arms.
Old Oct 29, 2015 | 03:47 AM
  #7377
abstrakg35's Avatar
My current rims is 18x7.5 +45 offset oem sport wheels Planning to purchase a set of staggered rims I'm currently on stech springs the setup I'm planning on running is 18x8 +40 on the fronts and 18x9.5 +40 on the rear my main concern is that how much clearance do I have in the rear because according to a rim tire calculator the rim will sit 0.8inch closer to the strut and I'm not too sure what the camber is at as of right now since I just installed the springs and haven't got to the alignment shop yet
Here is a photo of where I stand now
Old Oct 29, 2015 | 07:20 AM
  #7378
VenomGT9's Avatar
As long as you're not AWD the staggered won't be an issue.
If you want to know actually clearance, get under the car with a tape measure and make s**t happen. Most likely you'll have plenty of room for that type of offset but I'd look into something lower, around 20s/30s.
Old Nov 3, 2015 | 02:08 AM
  #7379
BlackG2017's Avatar
what is the best amount of camber to run for the best handling is it just to keep it within the factory range or 1.9-0.9 and also what are the best control arms for the front i just need something that's not to expensive and will do the job i already have spc camber arms in the back.
Old Nov 3, 2015 | 06:35 AM
  #7380
Man..fukc..do you know that the internet exists? I mean..you must, right?
Now I know why all these veteran members get salty when dikcheads ask dumb questions.. No offense..
There is no fukcin such thing as "perfect camber". (NOW HEAR THIS!!! TAKE HEED!! [at least take a fukcin note!!!]}
It is dependant on the roads you normally drive. Try doing a bit of research/learning and finding out what the words in your question mean. It all becomes self explanatory at that point. I promise
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
