Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#7426
Will 19x9 +30 Fit?
Sorry in advance if this question has already been answered I couldn't find anyting on the forms.
I was looking to purchase some wheels for a good Price and was wondering will 19x9 +30 will fit on my 06 g35 coupe on stock suspension will I need wheels spacers will
I have rubbing issues ? What Size tires 255/40? All Suggestions Will Be Appreciated
#7427
Get better fitting ones
Shoot for 19x9.5 and 19x10.5 +22 offsets for both give or take
#7428
Saw this on CL. Two questions please. I have G35 coupe
1. Is this a good deal ?
2. My fenders are rolled. Plan to get Stance Coilover soon. Will I need to run negative camber with this offset? Too aggresive? Only want flash look. Don't want to run negative camber. Thank you.
https://sacramento.craigslist.org/wto/5561291238.html
#7429
#7431
Thank you for your input. I will not get this than. Trying not to running negative camber. Just want the flash look. I will continue shopping. Thanks again.
#7432
Or pull the rears a bit and be able to run less neg camber
#7435
Razor scooter hahaha Its on a 03 coupe Will be lowered next week on BCs. Will i need to roll or flare the fenders? I already have 245/35r20, would that be to much stretch for a DD? Ive searched around and read mixed opinions.
#7437
Hey guys, I am on stock 19's with spacers 20mm/F & 25mm/R. The offset for front is +30mm and I added the 20mm spacers, what is the new offset? is it -10mm? or +50?
Goal is to get rid of the spacers through aftermarket wheels (with correct offset) that would looked flush like my current setting and also to learn about offsets. I hate numbers but if someone can answer my question above then I can figure out from there. Sorry if it's been asked before.
#7438
#7439
