Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#7456
Need a little assist guys, I own a 07 G35 coupe 6mt. I have H&R coil overs sitting on 20x8.5 and 20x10 in the rear. I don't want to use wheel spacers and I'm shopping around for new rims now. I want to purchase the correct off set to show a nice flush aggressive stance with running into any issues. What off set should i be looking for to avoid wheel spacers? Thanks for the help in advance.
#7458
I have a 2003 Infiniti G35 coupe. The car is stock height, and I don't have brembo brakes. I'm looking to buy a set of volk racing GT7s. The front wheels are 19x9.5/+22 offsets. The rear wheels are 19x10.5/+12 offsets. The front tire size is 225-45-19 and the rear tire size is 235-40-19. Will these wheels and tire fit well?
#7462
#7463
Can't say if wheels will clear brembos or not but if they do they will be sunken in with those offsets if you lower your car and will need to get spacers
#7465
Looking at the wheel I don't see a reason why it wouldn't clear brembo just can't say for sure. Yea with that drop you will def want to get some spacers. The wheels will be sunken in a bit. On a coupe you want offsets in the mid to low teens at least. But that's all preference tho so you might like the way it sits.
#7466
Originally Posted by westsai
i'm gonna try my luck here before i proceed to make another "will this fit" thread...
I have a 2003 G35 Coupe with Brembo
looking to get Enkei TS9,
Front: 18x8.5+25mm
Rear: 18x9.5+30mm
Will these fit with brembo?
Anyone has these wheels on their G?
Thanks
Front: 18x8.5+25mm
Rear: 18x9.5+30mm
Thanks
That's the determining factor
Not offset
#7467
What's a good camber kit/toe kit necessary for a 1.5" drop? I'd prefer not to have to buy the stuff, but if I can't get stock adjustment happy I'll do it.
Do NOT want coilovers.
Therefore, what is a smart stiffness upgrade from stock Sway bars? Godspeed sells a front/rear combo for a little more than $100. 40% stiffness increase front and rear.
Thanks!
Thanks!
#7468
#7469
Thanks!
Thanks!
#7470
2003 Nissan 350z rims on a 2006 G35X
My son gave me a set of factory rims off of his 2003 350z. They are 17 x 7.5 with 30mm offset front, and 17 x 8 with 33mm offset rear. Did a test fit on my '06 G35X and they stick out about 1/2" over stock. Will there be a problem with rubbing or with the AWD ? Looking to put together a set of winter rims/tires. Thanks for any help !
