Since I can't find an answer I figured it was time to post and hope to figure it out, I have a 2004 g35 coupe with brembos and I'm looking for wheels. I found some I like but the only offset they offer is +15 so my question is if I run 18x9.5 on the fronts and 18x10.5 on the back with +15 offset all around, will the front poke too much or will it sit about flush? Thanks in advanced
Everyone and their mom runs the same generic wheel width with the same offset. Look through this thread for 2 seconds and you'll find a dozen examples. Front and rear will be perfect, but 18's look small on a Coupe JS.
Hey everyone, in the process of getting new wheels and tires and I found wheels that I want to get they're 18x9.5/10.5 +15 offset all around, I was wondering if anyone could give me an idea of what this set up would look like and what size tires would be my best bet to go with. Thanks
245/35/18F and 275/30/18R on tires. And you need to read through this thread before you post any more questions. As Conissah said right above your post there's a lot of info here that answers all of your questions..........
Can anyone assist me in this temporary setup being im having my 2 front wheels repolished. Can i run my stock rays 225/40/19 up front with my 275/30/20 work rims on the rear. Just dont want to have vdc issues
Tia 05 coupe btw
my setup - toyo proxes 275/35zr19 9.5 front and 10.5 rear ~ I believe offset is +19 but not 100% sure....I initially had springs only and needed to roll the rear fenders, now I'm on Tien coils (required camber kit).
Kind of urgent - 06 G35 Coupe
Looking at possibly picking up a set of wheels tonight
19x9.5 +12 front and 19x10.5 +12 rear (current tires on the set are stretched)
Will the wheels sit flush if I am currently on stock suspension? (I plan dropping sometime around August)
Hello y'all . Not sure if this question has been asked. But can you run 19in rim with 9.5 width 35 + offset all around without VDC issue ? Ive read some post but didn't have the offset I'm asking about .Tires i will be using are 225 40 all around . Im not lowered and is on stock sport suspension in a coupe.
Thanks!, before I make he purchases of that wheel. May I asked why the manufacturer of the rim I'm buyin from says it will not work for the front . There out of stock for the 19x8.5 24 offset , witch they told me that will fit no problem. Sorry for asking these questions. It just that I don't want to spend the money and don't have them rub or have vdc issue
Can someone please tell me how these would fit? And will the front wheels clear the brembo calipers without adding spacers?
I am on swift 1inch springs. Coupe.
18x10 XXR 968
225/40/18 in the front
255/40/18 in the rear.
I don't want any rubbing or having to roll fenders. I also want a relatively comfortable ride as I lug my kids around a lot. Gonna go get em tonight if all is good.
