Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Oct 31, 2010 | 04:04 PM
  #1276
MST219's Avatar
edit..
Old Nov 2, 2010 | 12:17 AM
  #1277
N@eem's Avatar
im planning on getting g37 19s on my 04 coupe. i know i will need to get the g37 lug nuts but other than that what all will i need to make them fit on my coupe. also if anyone has any pics of a g35 coupe with them
Old Nov 4, 2010 | 11:38 PM
  #1278
G-MAN (CANADA)'s Avatar
Wondering if I can pull this off on my 04' sedan
20x8.5 - et +42
20x10 - et +38
if so what rear tire size can I run without worrying about rubbing issues?
Thanks
Old Nov 6, 2010 | 12:47 AM
  #1279
410g35's Avatar
Just wondering if someone could answer my question about a 19" setup for my coupe. I'm wanting to order a set of Weds TT7R's and the widest they come in for 19's are 10. I'm planning on 19x9.5 fronts and 19x10 rears. What would be the best offset that would fit my car while offering me the biggest lip? I'm planning on rolling my fenders and am currently running a K Sport pro kit air suspension. I've checked other setups on Rimtuck.com and i've seen +2 being the lowest for the fronts and -13 or +22 for the rears. My goal is to fill the fenders as much as possible while having as big of a lip as I can. Any help or insight would be greatly appreciated
Old Nov 6, 2010 | 02:24 AM
  #1280
NYYBaseball423's Avatar
I have 245/40/19 tires all around on a 19x8 wheel with +34 offset (I believe) all around. Would I rub if I dropped on coupe H&R's? Would I need a camber kit? Thanks in advance.
Old Nov 6, 2010 | 05:22 PM
  #1281
pastuch's Avatar
Are 15 inches too small?
I have a set of almost new 205/70R15 Michelin X-ice tires.
I was wondering if I put them on some 5x114.3 rims if they would fit on my G35?
I know they are within 1.4% of the original 225/45R18s that are on the G35 now.
Old Nov 6, 2010 | 05:54 PM
  #1282
whoisthis's Avatar
Will the edges of rims stick out on 18x10 rims with 245/45/18?
Old Nov 7, 2010 | 02:03 AM
  #1283
OCG35's Avatar
Offset/Camber Calculation
Offset/Camber Gurus... do you have answer?
Current camber is -1.3 on all four... If I get wheels that are extend 10mm, how much camber do I need to be where I am now?
Specific specs:
current: 8.5 +15 (-1.3 camber) front and rear (sits 5mm inside fender line)
potential new: front 9.5 +17(extends 11mm), rear 10.5 +30 (extends 10mm)
I've never been able to confirm mm to camber ratio... I'm thinking 10mm = 1 degree (but I've read as low as 5mm = 1 degree)
If in fact its 10/1 will I now need -2.3 to sit where it is now? To add more question to the formula, I'd like to be about 3mm tucked from where I am now - so would that mean closer to -2.5 camber?... I'm calculating it as current -1.3 plus additional -1 for the added 10mm (and another couple tenths of a degree to bring it in a few more mm).
Hope the way I questioned it isnt too confusing
Old Nov 7, 2010 | 02:39 PM
  #1284
IVANISINLA's Avatar
Tires 255 35 20 in the back ?should I?
My first time here and I don t know much about tires I'm planning to buy tires but I'm debating If I should get 255 in the back or 245 my rims are size 20 and I had only 245 35 20 all four tires. so far i have hankook v12 and yokohoma s drive on my mind.
Old Nov 7, 2010 | 10:58 PM
  #1285
Swivel's Avatar
Moderator
Specific specs:
These guys seem to think it's about 5mm, though they are calculating on a ~300mm radius; on a 26" OD tire (using my 255/35-19 rear size as the example), it should be about 330mm. So 6mm per degree might be a good approximation.
http://www.ziptied.com/forums/index.php?topic=535.0
Old Nov 8, 2010 | 10:14 AM
  #1286
OCG35's Avatar
^^^ thanks for the response... so I'd have to be -2.5 with the new wheels to be where I am noe with current wheels... that sux I wish the ratio was 10mm for 1degree
Old Nov 8, 2010 | 10:20 AM
  #1287
Swivel's Avatar
Moderator
How do you feel about pulled fenders, LOL!
Old Nov 8, 2010 | 10:53 PM
  #1288
OCG35's Avatar
wow, great idea - why didnt I think of that
Old Nov 8, 2010 | 10:58 PM
  #1289
Gdup35sedan's Avatar
ENVautoDetailing.com
Just stretch your tires Mike! We all know that you love the HellaFlush scene!!!
+1 for 6mm to 1* of camber. I put the SPC hub spacers (+2.0* static camber) and it was about the same as a 12mm spacer.
Old Nov 9, 2010 | 12:16 AM
  #1290
OCG35's Avatar
^^^ thanks Grant... maybe you can help me find the right wheels
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
